One of my favourite vintage watches from the 70s houses an automatic ETA 2772. I have serviced it and everyday use is unproblematic. At full wind its amplitude is about 280 degrees dial up and dial down, and about 250 degrees in all other positions. The beat error varies between 0.0 ms and 0.3 ms depending on position and the rate is normally +/-5 seconds per day.
However, when I take the watch for a brisk walk and some jogging while also moving my arms quite vigorously for about 40 minutes, the rate speeds up to about 400 seconds per day. As soon as I stop working out the rate returns to its normal +/-5 seconds per day.
So, I have two questions:
a) Why does my watch start to rush when I work out, swinging my arms, and
b) Is there anything that can be done to fix it?
Edited by VWatchie
You probably should time the watch in six positions and write all the numbers down. So style up dial down and four separate  Crown positions  or the dial on the watch like 6 o'clock high 6 o'clock low something so you know what all the four positions are. Then typically on any watch you wind it up let it run about 1530 minutes before timing but wind it up all the way until you feel the mainspring slipping is this an automatic  or  wind it up until its tights even though it is an automatic then time it.. If your mainspring is not slipping it's going to get that little bit of extra energy  and it's going to screw up timekeeping possibly. You might even put it on the timing machine and when it's stable slowly wind it up and see if you can wind it up to the point where it speeds up.. Then you're also doing six position timekeeping to make sure there isn't some position where they hairspring is touching something it's not supposed to.
A: because laws of physics do exist inside of a watch escapement. Vigorous movement will add force to the balance wheel, causing it to store more energy and run faster. The amount of energy stored will depend on the duration of the activity...and that will determine how long it takes for the additional force to be expensed and return back to normal rate.
B: nothing you can do its the laws of physics at work.
In dynamic state and with associated random high amplitude, hairspring may stick.
A video of HS  as you manually complement barrel power, would reveal such sticking. Should you set up for vid, I try to capture the guard pin as well.
I have to agree with JohnR in principal here. It's not typical for a movement (especially a quality movement like that) to encounter a terrible error like that. Escapements like these are designed to be isochronous to the extent that they should not vary considerably in rate with the amount of energy that is transferred into them, unless they are driven into banking. I exercise most days and I've never encountered any of my watches doing anything like that. Maybe I've been lucky.
The movement is a much older eta, so it could very well need a cleaning, the hairspring could be sticking like NUCE said causing the dramatic increase in rate.
Wear and damage brings imperfections, Is this balance complete the Genuine? or rebuilt and properly? Is it as perfect as it left the company? Same questions apply to the rest of escapement.  Oscillations can get out of control in dynamic state if a faulty guard pin isn't guarding right.
I think VWatchie posted a walkthrough of this, helps to browse over it.
Regards
19 minutes ago, eric9000k said:
Time should be passing more slowly if you accelerate, maybe it's just general relativity.
Not if HS sticks.
Shipping .. — Reflections
  • Haha 3
Ya, I remember the clean and picture quality stuck that walkthrough in mind.
I wonder if you had discussed or paid special attention to the guard pin back then. One picture shows the fork short of guard pin.
IMG_2778.JPG?psid=1&width=1003&height=897
This is the final picture of the pallets during the assembly of the actual watch that is rushing when moving my arms around while working out. I browsed through all of the pictures where the pallets are visible but in none of them the guard pin is missing. Perhaps that's not what you're saying? Can you copy and paste the picture in which "One picture shows the fork short of guard pin"? Hopefully that will make it clear!
EDIT: No I haven't tested the clearance of the guard pin but I'll consider it.
Edited by VWatchie
In my opinion, mislocking would be less likely to cause a rate increase like that. I think it's more likely that the balance is naturally oscillating at a higher frequency.
Edited by rodabod
If the guard pin gets pushed in towards fork pivot (say during the clean) the created  excess clearance from the roller table lets untimely exist of guard pin out of the roller hollow, in the event of vigorous wrist motion.
Just by look, guard pin seems Ok in the pic you show above, motion picture should show if such excess clearnace exists.
No need to accelerate,  time passes slower by just motion.
Time is the amount of motion. The faster you spend of the amount, the sooner you run out.
I'd be interested to know if you have ever encountered a mislocking (due to lack of safety roller function) lever which has caused a watch to gain considerably like this. I certainly haven't. Mislocking of that nature can lead to the balance being "over-banked" which stops it entirely which is certainly something I have experienced before.
1-Imperfect hairspring coil can foul itself when amplitude gets too high so the rate goes fast , until such time that  HS coil jumps back to normal.
2- Loose and pushed back guard pin, fails to guard the roller table- impulse jewel properly, in which case if the balance wheel gets in a hurry on wrist it is susceptible to the condition in section 1.
Faulty guarding by the pin, can let the condition for sticking to come about.
So, I have some interesting and encouraging news. Instead of analyzing what could possibly be wrong with my automatic ETA 2772 watch, I studied how exactly I move my arms when working out. It turns out that after each interval training session I would jerk my elbow quite violently while walking and recovering my breath. I'm pretty sure this induces a very unnatural stress on the balance wheel, and my elbow, so decided to go slightly easier without really sacrificing any natural motion of the arms.
The result? My watch won't rush and works perfectly normal. I believe I read in an automatic watch manual some years ago that the watch should not be subjected to sudden impacts like when playing golf or tennis. The manual didn't state what "damage" it would do, but I think I know now. So, I believe @saswatch88 was right on the money in this post.
I think the danger mentioned in the manual is related to dislodging the regulator / hairspring and thereby messing your timing up.
Anilv
Got a test I think would be interesting to try. Fully wind it and put it on the time grapher. Then with a piece of peg wood or something soft grip the teeth on the barrel and push it in the direction in which it unwinds with gradually increasing force. How would the rate change/line look as you're doing this?
I agree, that would be interesting! If/when I get around to it I'll report back.
When I worked out today I tossed around my arms a little more vigorously than the previous time, but not excessively, and again the escapement/rate started to rush. Not quite as much this time but still definitely unacceptably to about 133 seconds per day. So, there's definitely something that's not quite right. I'll try to find the time to test @CaptCalvin's idea.
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
