Vintage Watch Bench Restore
JerseyMo
One of the things about my interest in time pieces is the long and rich history. so what better way to get a sense of it than to sit at a true watchmakers bench.
Here is where it begins -  all the draws are to the right.  The shelf is not original and you can see the back has been cut out.
The lower door doesn't look correct either.  Most noticeable damage is that many of the joints need to be re-glued. I will start with giving it a good wash with wood cleaner.
And here it is after a good scrubbing, See how the wood has already become lighter in color.
 - that board will be what I use to repair the back panel.
  • Like 5
Hi Mo  Its beginning to look like somebody loves it 100 % better for the washdown
it is looking better and each task gets it closer to getting it back to work. two draws done today and I cleaned up one joint in preparation for re-glue.
That's pretty much a dead ringer for the bench I dragged over with me from the states. I found a top here with the slanted arm rests that fit pretty much perfectly and got the height to a usable level (the old school U.S. benches are too low for me in general, I'm 6'). It's been my main bench since I struck out on my own- and I love how European watchmakers react to it!
You'll get a lot of good use out of that.
using a liquid stripper was moving super slow so I got more aggressive today with sanders.  Much faster!
Hopefully tomorrow is nice weather and I should be able to finish all the sanding.  The wood will than be oil treated and waxed. Well that is the plan anyway :)
All done and it came out just as I thought.  Still showing the scars of years of use but, no longer will all the dirt and grime. :)
...now the real task of having to reorganize the watch room.
Edited by JerseyMo
  • Like 6
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
