Vintage Watch Bench Restore
JerseyMo
One of the things about my interest in time pieces is the long and rich history. so what better way to get a sense of it than to sit at a true watchmakers bench.
Here is where it begins -  all the draws are to the right.  The shelf is not original and you can see the back has been cut out.
The lower door doesn't look correct either.  Most noticeable damage is that many of the joints need to be re-glued. I will start with giving it a good wash with wood cleaner.
And here it is after a good scrubbing, See how the wood has already become lighter in color.
 - that board will be what I use to repair the back panel.
  • Like 5
Hi Mo  Its beginning to look like somebody loves it 100 % better for the washdown
it is looking better and each task gets it closer to getting it back to work. two draws done today and I cleaned up one joint in preparation for re-glue.
That's pretty much a dead ringer for the bench I dragged over with me from the states. I found a top here with the slanted arm rests that fit pretty much perfectly and got the height to a usable level (the old school U.S. benches are too low for me in general, I'm 6'). It's been my main bench since I struck out on my own- and I love how European watchmakers react to it!
You'll get a lot of good use out of that.
using a liquid stripper was moving super slow so I got more aggressive today with sanders.  Much faster!
Hopefully tomorrow is nice weather and I should be able to finish all the sanding.  The wood will than be oil treated and waxed. Well that is the plan anyway :)
All done and it came out just as I thought.  Still showing the scars of years of use but, no longer will all the dirt and grime. :)
...now the real task of having to reorganize the watch room.
Edited by JerseyMo
  • Like 6
    • The epilame under the oil will also be removed
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
