Help to identify ladies watch movement
Ramone
Hi guy's, I need help with identification of this movement, it has no markings anywhere of a movement maker or number,  the only marking is " Swiss made" and " 15 jewels "
The reason that I want the movement identified is because it needs a new hairspring, so knowing what it is would be a great help
Thank you in advance
Hi just a thought  The bestfit books one and two are on this site posted by Old Hippy some time ago I think there was a flume indentification section on on of them. I have found the catalogues and attached them the password is tickandtock.  Theyare in PDF format so you gan page through them.
bestfit_part1_(1).pdf bestfit_part2_(1).pdf
  • Thanks 2
27 minutes ago, watchweasol said:
Hi   One way is by the flume (setting lever spring) there are books to reference it.  By the look of it its 30s 40s era.
Thank you kindly, I'll look up and pay particular attention to the setting lever spring shape
bestfit_part1_(1).pdf 151.32 MB · 1 download bestfit_part2_(1).pdf 66.3 MB · 1 download
Thank you so much, the books would definitely help,  it's so hard to guess who made the movement, even the case which is sterling silver has no info, will try my best to find out and let yourl know the outcome :)
I need certain HS , 500 to 1000 pieces, know the caliber, not the CGS for its hairspring.  Question; How do you go about finding  compatible hairspring once you know the caliber?   TIA.     Best
Guys I have looked through the best fit books, I ddnt find an exact match
However, the Eta 651 is scary close, what are yourls opinions?  I see it has its own escape wheel bridge/cock unlike the unknown movement,  and the setting lever spring slightly differ, I'll attach pics of the ETA 651
Have you found the tech sheet for your caliber? They often actually list the cgs. Otherwise there are tables that correspond cgs to ligne size, which would be pretty close. If you need it spot on you'll need to have a selection of springs of known cgs, vibrate one that seems about right, check the diameter, then there's a simple formula to determine the correct cgs.
Found one of the tables, it's in French but easy to figure out.
If doing the test spring process, the formula is K=K' (D/D') 2
K is the CGS number you're looking for
K' is the CGS of the spring you test
D is the diameter of spring you need, at the pinning point
D' is the diameter of the correctly vibrated test spring at the pinning point.
Sorry to the OP Joe and I are hijacking the thread a bit, maybe a mod could move it to a new thread?87744470_cgslist.thumb.jpg.0a41658a0bac2adfa6a70505c1172faa.jpg
Hi Nickelsilver, Thank you for all the help.  Will search for the tech sheet.
I have many used genuine hairsprings and balances that I have been vibrating together. Need to place order for more hairsprings of compatible springness.
Been trying to experimentally find a compatible HS of known CGS.
 Strength is proportional to area of the coil outer circle.
I think I may find CGS direct out of this tables.
Will keep you posted.  Thank you, great help.   Best
Your measurements of 8.75 x 21mm put this at a ligne size of 3.75 x 9.25 (or perhaps 4 x 9.5). There aren't that many movements of this size and the most common is the FHF 59 (which other manufacturers used as well and gave their own movement ID to). Unfortunately it's not this as the keyless works and bridge layout are completely different to your movement.
Which brings me on to your probability of an ETA 651. That's a no ... at 10 x 22.7mm it's larger than yours and of course the keyless works (and bridge layout) are different. In my searching I had also come across the ETA 746 but it's the same story.
I have spent ages looking through stuff trying to find your movement but no luck. :mellow:  I've found setting lever springs that look similar but then a no-go on the movement size; a (Van) Buren movement looked promising but didn't tie up etc. etc.
I hope someone strikes lucky!
Thank you so much for the help and the time you spent searching
Still no luck on my side, but will keep searching, hopefully I'll find out what it is
Thanks again for the help
Really appreciate it and appreciate this forum
The information from the experienced are priceless :)
13 hours ago, Nucejoe said:
Yes I hijacked this thread, did not mean to , sorry sorry.:)
No need to apologise or to move,
They are related
After all I need to identify the movement because I need a hairspring
I unfortunately never learn about CGS and hairspring formula yet but would love to in the future
Thank you
They are related
Thank you
Just a quick intro,  CGS is( a system of units) used in analysis of  physical systems. C stands for centimeter, G for gram, S for seconds. . In this case, the relation between, torque( force applied at radius R) , springness and the amount of the resulting bend in a hairspring.  CGS is suitable for and adapted in horology.    Sounds difficult , it is easy.
Best
  • 4 weeks later...
Hi guy's,  I miraculously found a watch on an online auction with the exact movement,  the setting lever spring shape is slightly different but the movement is identical to the unknown in question,  and this movement that I found has a stamp / makers logo on the main plate under the dial
However I have never seen this logo,  can anyone tell me what it is?
Also there's no movement number under the balance cock,  just the letter " N"
Thank you
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
