Pallet Warmer Project
Mark
Editing a video on the construction at the moment.
Need to reset the pallet stones in a vostok which was loaded up with too much shellac. Unfortunately my pallet warmer is missing - searched high and low - I suspect it's in pallet warmer heaven. So I made a new one. Hopefully this will be an interesting video for some. In fact - I made two. Will do a giveaway to a winner for one of them. Details will be announced in my next video which will show how I made these and the video after that will the Vostok restoration where I will demonstrate how they are used.
In the meantime - if anybody wants to build one themselves, I have attached the plans to this post. If you do make one then post pics :)
Pallet Warmer Plans.pdf
Nice one, thanks for the plans.... Strangely enough I was just looking for mine before reading this and found it.
Maybe your lost one is with Bagpuss?
Yikes - bagpuss. Now that's a blast from the past!
Sent from my SM-G950F using Tapatalk
  • Haha 2
32 minutes ago, watchweasol said:
Hi  Likewise Old H do you remenber Andy Pandy and Teddy , Watch with Mother,   not forgetting the Interlude....
Watch with Mother Monday
Andy Pandy Tuesdays
Rag Tag and Bobtail Wednesday
Bill and Benn Thursday
The Wooden Tops Friday.
A nice video Mark. What type of lathe are you using?
@oldhippy Sorry for late reply.
It's a mini bench lathe made by a company called Optimum. A relatively new addition to the workshop along with the mill.
1 hour ago, TheFixer said:
I have the copper plate so just need some brass.
Any chance of a picture with the wooden holder without the tool itself?
You can see it clearly in the video Mark uploaded, he shows the machining out process but it could be easily done with a chisel or by tacking sides onto a flat piece.
On 11/15/2019 at 10:59 PM, oldhippy said:
Thank's Mark for the reply and nice photo. That's a new one on me I'll look that one up.
Is it the Light Duty Lathe Optimum TU2004V 240v Variable Speed?
Absolutely - thats the one. So far I have had a few issues with it but noting major.
The gib in the compound slide was bent - easy fix but I need maybe add a couple more gib screws to make it more smooth and it came with an extraordinary amount of grit on the lead screws and ways. This is common with chinese lathes I think but didn't expect it with "German quality" - lesson learned :D
I would like to install a thrust bearing too, to minimise  backlash. But the parts I have made so far are quite accurate not bad for a light duty lathe. Not unhappy.
Thank you Mark that is very helpful.
  • 4 weeks later...
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly filed the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
    • You can try a rubber on that the sort for rubbing out a pencil.
    • Determined that the nos staffs are the correct length for the movement by fitting the just the staff and i should be able to find a wheel and hairspring to fit. Problem is the roller hole is too large.
