Same as @oldhippy, a hard or medium arkansas stone that sets in a wood box. Plus, a bit of oil. Occasionally I wipe the stone with with oil to remove metal grit and keep the stone open.
Cheers!
Grinding at an angle is right and can be easily done with a $3 roller, but before going to that motions inspect the blade for damage and the check in the slot of the screw you will be working, they can all be a bit different. If the tip touches the bottom what you want is to widen the blade tip thickness, that is done grinding the frontal edge as mentioned, not the sides. It will make a world of difference when it comes to grip.
Edited by jdm
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
