I'm going to replace the crystal.. well, I'm going to try
Kalle Slaap from Chronoglide Watchmakers has said a lot about him. I know about the George III watch. Thanks for posting.
Is this your first attempt, the teeth certainly need better cutting. Its a hell of a lot better then my first one.
Thank you for posting this! I just found my grandfather’s watch which looks exactly like the third one pictured in the original post… although it has a bracelet instead of a strap. Can someone tell me what C.P.C. stands for?
The final result is not perfect looking, but is working well. The wheel is pritty small - the OD is 1.8mm
