I'm looking for tips on how to get a really sharp point on pegwood etc. I've tried a pencil sharpener, which just puts a long, thin tip on the wood, without bringing it to a point. I've also tried a scalpel, but I don't like the facets and edges leading up to the point. I want it nice and round if possible. I know it's possible. I even saw a perfect example in a post I read recently (poss. from Nickelsilver). So what do others do? Use a file, or abrasive paper? I tried this too, but I still never got a point sharp enough to clean jewel holes for example.
I've used cocktail sticks, or rather toothpicks, which are "free" from the works canteen. They work fine for general cleaning and manipulating small parts. They are not sharp enough for pegging jewels though.
I use a cutter knife, the kind with replaceable blades that break off in like 10 little sections. Facets are good!- they help clean. If you're doing jewel holes you need to resharpen after each one, you'll get quick fast. I use a loupe. I also do a lot of small watches with 0.07mm jewel holes...
2 hours ago, oldhippy said:
I just used a sharp pen knife. I also used cocktail sticks.
OK, seems like  the experts use knives. Do you actually cut, or scrape? What kind of angle are you trying for at the tip? Do you need to clean the dust, fibres or flakes away after sharpening, and if so, how?
I use both "cocktail sticks" (got to love the British sense of propriety) and peg wood.  Use a disposable scalpel and "whittle" the point.  When I'm getting close to a point, I simply cut less and less by reducing the angle of the blade to the stick.  Use your magnification to look at your work.  And yes, repeat the pointing exercise between each jewel unless you move to one with a bigger central hole.
Good Luck,
RMD
Edited by rduckwor
typos
For general just pushing and holding I cut a steeper angle maybe 30 degrees, for fine pegging of jewels a shallower angle of 15-20 degrees. Cut, not scrape. I find that pegwood is faaaaar better for fine work than toothpics or bamboo skewers or whatever. For clocks I do use lots of toothpics.
Like others I just use a knife.
I have a small quality 2 bladed Barlow pocket knife I've had for so long I don't even remember how I got it.
I have the small blade sharpened nicely and just use that.
I try to keep it evenly sharpened on all sides, but as said above facets are good, they help remove any dirt.
I have a large amount of pegwood of many sizes so I have never used anything but pegwood, so cant tell you if it is better than kebab sticks or toothpicks, or any of the other alternatives, but pegwood is cheap and lasts ages so I see no need to try something cheaper.
Tony
  • 2 months later...
I wanted to pick up on this again, as I'm still not satisfied with the results I'm getting. Here are some pictures:
WIN_20191103_18_55_21_Pro.jpg.0ab8bf192c93c9d5c29424adf29792ea.jpgWIN_20191103_18_57_31_Pro.jpg.ef782810a4bd7c6091e1afb21963cdb4.jpg
That is really the best I can do with a freshly sharpened scalpel blade and the 3mm dia. pegwood I have. I don't think the point is sharp enough or long and thin enough to really get in the hole and clean it. Also, I'm worried about the tip breaking off in the hole. A flake dropped of while I was taking the first photo. You can see it at 7 o'clock.
I read in another thread that there are different qualities of pegwood. Is that my problem, or am I just not cutting it with the knife?
My dog sheds loads of sturdy bristles. I am seriously considering using them instead.
You can also try sharpening a toothpick harder wood, no flakes. However, I always use peg wood.
    • Hi 122146 - welcome to WRT 😊
    • You could try a soft-solder repair on that
    • Hi Logan, welcome to the forum 👍
    • So I recently picked up a slim 6105 which had a badly damaged dial (posted in another thread). I couldn't really live with that given I had another dial handy, also in not great condition but with added bonus of having a better lume job and actually being fully attached to the dial plate!  So what to do with that damaged dial - I tend to think they should be in watches. Well...  A 6105 mid case and crystal assembly punt arrived from Italy yesterday, which I've frankened back into a working piece with the dial... Damaged dial now sits behind damaged crystal in an original case, currently powered by 6106 (with a 6106 caseback on to reflect this... I've cleaned up the original crystal up to a point, but kept it fairly beaten to distract me from the dial, my markers and it's not very satisfying lume job - it's not awful but it's glossy which I don't like. Also has a 6139 bezel on it for now because that's all I could find - I couldn't live with it naked and don't mind it tbh, though will keep an eye out as ever.  So yes, here you go - another 6105 (almost!) back to life. I'll also keep my eye out for the correct movement and perhaps a better dial in time. Caseback might prove tricky/expensive. I know Frankens aren't to everyone's taste but I do enjoy getting these back into working form. Better a working/worn watch than a sat in parts draws imo. And the good news here is that, thanks to the repro service crown, this is the only one I have I could actually feel safe to swim in!
