first rebuild
gary17
Hi
I have just started my first rebuild.
I'm hoping to get help.
The pictures down below are my first glitch, when i was disassembling  the movement the spring just fell out so i'm unsure how it should fit.
I think its the click spring?
Does the part that sticks out go behind that pillar?
It looks to me it should.
Sorry i don't know all the tech terms but i'm learning.
please feel free to aid my education.
cheers
gary
Looks like some sort of yoke spring. A yoke is usually a long piece that gets slotted in the slot on the sliding pinion. Usually there are 2 parts that the stem get threaded through. There flat one is the crown wheel and the cylindrical part is the sliding pinion. The yoke spring would push the sliding pinion towards the crown wheel through the yoke.
5 hours ago, gary17 said:
Hi
cheers
gary
Find tech terms by ETA in Eternaltools.com .
That spring is a "yoke spring" also known as a "return bar spring". It presses on the yoke/return bar. Make sure you get the yoke in place first, then the yoke spring, and finally place a bit of grease between the spring and the yoke where they meet. Do not grease before the spring is in place. Also, you must assemble the winding pinion, sliding pinion (also known as the clutch), and stem before you assemble the yoke and the yoke spring. Here are some pictures that you might find useful:
y4mS7t1j3vFE9fnE74XMXFa37E01SIqaRR4cnbNY
OMEGA cal. 601
y4mfbG-czH2Z_VRDpzoHYNWWwWzoucR7BXuOmJPI
VOSTOK cal. 2409
y4mLq8PCrfnvmDaeDZrx5_71r-TMeALrmkDZxHBJ
AS cal. 1203
Edited by VWatchie
misspelling
Thank you for explaining how this part of the keyless works operates! However, the terminology is a constant source of confusion in our trade. The part that you name a crown wheel is indeed a winding pinion and it drives the crown wheel mounted on the barrel bridge.
Eternaltools.com gives ETA's version of parts name( illustrated). Considering that the said expansionist company bought many others, the said version is expectedly the most common.
Yes I've realised the mistake after it was too late to edit.
Not sure I understand the Eternaltools.com comment. I looked at the website and saw nothing relating to ETA movements, only a tool seller.
I see they put out a new site, which is what you saw. Go to the old site,
eternaltools.com/blog/swiss-eta-watch-movement-parts
No telling if the old site stays or not, I see if it lets me copy the diagram for future references.
Regards
As amazing as WRT is, the limited time for editing is IMO very, very annoying! I think we should be allowed to edit our posts for at least a week so that we can update and add info as we go. As it is now, we must basically scroll through the entire thread for new posts from the OP to find any additions or updates. Well, JM2C!
Edited by VWatchie
posted to early...
  • Thanks 2
I think anyone who tried editting agrees with you. This will also reduce the amount of corrective post perhaps even double posts.
I think the time limit is to avoid confusion later. If someone asks how to let down the mainspring and the first reply is "take out the pallet fork" then 10 replies saying noooooo then 1st guy edits and now the thread doesn't make sense.
I don't know the limit here but I don't think any forums I visit allow more than a few hours, some less some more.
Editing is more for typos than content
(Just edited this post 3 times!)
Regards
Excellent info at link! Thanks for sharing.
The current time limit is, I would guess, around 10 minutes, but some times this is really a little too short.
I tend to post, read my post, realise what a load of nonsense it is, edit it, find out I've still left in a couple of typos, re-edit it, only to find nope.. I'm too slow witted and I've run out of time.
If we had a "remorse period" of say 20 mins, then that would probably be better.
3 hours ago, oldhippy said:
Would you like me to message Mark? See if it can be changed. What sot of time do you suggest?
30 mins.
Most fruitful mistake.:geek: make more.
The last post I wrote on the F10 forum (WUS) was 5 days ago and I can still edit it, which feels reassuring should I find out that I've made some silly, embarrassing, or even serious mistake. What I do as a courtesy to other members is type the word "EDIT" below the original text and then add what I have to say. I think a week would be suitable/OK. There are pros and cons allowing more time for editing, but I'm very much like @AndyHull so my posts would on occasion benefit from it.
Here is Marks complete reply.
Hi, no i'm sorry, this is not something I am willing to make unlimited.
However, I have changed regular "Member"'s to be able to edit within 1 hour - currently only 799 out of 5700 members have contributed more than 10 posts in order to become upgraded to "Member" from "New Member", sad isn't it!
"New Members" are locked in at 10 minutes. "New Members" are automatically upgraded after 10 posts.
"Moderators" have unlimited time.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
