Hi
I have just started my first rebuild.
I'm hoping to get help.
The pictures down below are my first glitch, when i was disassembling  the movement the spring just fell out so i'm unsure how it should fit.
I think its the click spring?
Does the part that sticks out go behind that pillar?
It looks to me it should.
Sorry i don't know all the tech terms but i'm learning.
please feel free to aid my education.
cheers
gary
Looks like some sort of yoke spring. A yoke is usually a long piece that gets slotted in the slot on the sliding pinion. Usually there are 2 parts that the stem get threaded through. There flat one is the crown wheel and the cylindrical part is the sliding pinion. The yoke spring would push the sliding pinion towards the crown wheel through the yoke.
What movement is this? I can't make out the name. I believe you have the spring reversed...just flip it over and it should rest against the yoke...Here's a picture of a Bulova movement so maybe it will help you orient the spring...
5 hours ago, gary17 said:
Hi
cheers
gary
Find tech terms by ETA in Eternaltools.com .
That spring is a "yoke spring" also known as a "return bar spring". It presses on the yoke/return bar. Make sure you get the yoke in place first, then the yoke spring, and finally place a bit of grease between the spring and the yoke where they meet. Do not grease before the spring is in place. Also, you must assemble the winding pinion, sliding pinion (also known as the clutch), and stem before you assemble the yoke and the yoke spring. Here are some pictures that you might find useful:
y4mS7t1j3vFE9fnE74XMXFa37E01SIqaRR4cnbNY
OMEGA cal. 601
y4mfbG-czH2Z_VRDpzoHYNWWwWzoucR7BXuOmJPI
VOSTOK cal. 2409
y4mLq8PCrfnvmDaeDZrx5_71r-TMeALrmkDZxHBJ
AS cal. 1203
Edited by VWatchie
misspelling
Thank you for explaining how this part of the keyless works operates! However, the terminology is a constant source of confusion in our trade. The part that you name a crown wheel is indeed a winding pinion and it drives the crown wheel mounted on the barrel bridge.
The spring is the wrong way round. That shape of spring is known as a shepherd’s crook. VWatchie has put up some very good clear photos for you so you can see. His first one of the three is for your movement.
Eternaltools.com gives ETA's version of parts name( illustrated). Considering that the said expansionist company bought many others, the said version is expectedly the most common.
Yes I've realised the mistake after it was too late to edit.
Not sure I understand the Eternaltools.com comment. I looked at the website and saw nothing relating to ETA movements, only a tool seller.
I see they put out a new site, which is what you saw. Go to the old site,
eternaltools.com/blog/swiss-eta-watch-movement-parts
No telling if the old site stays or not, I see if it lets me copy the diagram for future references.
Regards
As amazing as WRT is, the limited time for editing is IMO very, very annoying! I think we should be allowed to edit our posts for at least a week so that we can update and add info as we go. As it is now, we must basically scroll through the entire thread for new posts from the OP to find any additions or updates. Well, JM2C!
Edited by VWatchie
posted to early...
  • Thanks 2
I think anyone who tried editting agrees with you. This will also reduce the amount of corrective post perhaps even double posts.
@gary17 would be nice to know what brand/mvt it is....
@oldhippy please do as it would be a very good thing to have editing for a longer or even unlimited time...we are not selling here so why not be able to edit?
I think the time limit is to avoid confusion later. If someone asks how to let down the mainspring and the first reply is "take out the pallet fork" then 10 replies saying noooooo then 1st guy edits and now the thread doesn't make sense.
I don't know the limit here but I don't think any forums I visit allow more than a few hours, some less some more.
Editing is more for typos than content
(Just edited this post 3 times!)
Regards
Excellent info at link! Thanks for sharing.
The current time limit is, I would guess, around 10 minutes, but some times this is really a little too short.
I tend to post, read my post, realise what a load of nonsense it is, edit it, find out I've still left in a couple of typos, re-edit it, only to find nope.. I'm too slow witted and I've run out of time.
If we had a "remorse period" of say 20 mins, then that would probably be better.
3 hours ago, oldhippy said:
Would you like me to message Mark? See if it can be changed. What sot of time do you suggest?
30 mins.
Most fruitful mistake.:geek: make more.
The last post I wrote on the F10 forum (WUS) was 5 days ago and I can still edit it, which feels reassuring should I find out that I've made some silly, embarrassing, or even serious mistake. What I do as a courtesy to other members is type the word "EDIT" below the original text and then add what I have to say. I think a week would be suitable/OK. There are pros and cons allowing more time for editing, but I'm very much like @AndyHull so my posts would on occasion benefit from it.
I messaged Mark yesterday. Waiting for reply. I'll let members know on this thread, unless Mark has other means of doing so.
Here is Marks complete reply.
Hi, no i'm sorry, this is not something I am willing to make unlimited.
However, I have changed regular "Member"'s to be able to edit within 1 hour - currently only 799 out of 5700 members have contributed more than 10 posts in order to become upgraded to "Member" from "New Member", sad isn't it!
"New Members" are locked in at 10 minutes. "New Members" are automatically upgraded after 10 posts.
"Moderators" have unlimited time.
    • So I recently picked up a slim 6105 which had a badly damaged dial (posted in another thread). I couldn't really live with that given I had another dial handy, also in not great condition but with added bonus of having a better lume job and actually being fully attached to the dial plate!  So what to do with that damaged dial - I tend to think they should be in watches. Well...  A 6105 mid case and crystal assembly punt arrived from Italy yesterday, which I've frankened back into a working piece with the dial... Damaged dial now sits behind damaged crystal in an original case, currently powered by 6106 (with a 6106 caseback on to reflect this... I've cleaned up the original crystal up to a point, but kept it fairly beaten to distract me from the dial, my markers and it's not very satisfying lume job - it's not awful but it's glossy which I don't like. Also has a 6139 bezel on it for now because that's all I could find - I couldn't live with it naked and don't mind it tbh, though will keep an eye out as ever.  So yes, here you go - another 6105 (almost!) back to life. I'll also keep my eye out for the correct movement and perhaps a better dial in time. Caseback might prove tricky/expensive. I know Frankens aren't to everyone's taste but I do enjoy getting these back into working form. Better a working/worn watch than a sat in parts draws imo. And the good news here is that, thanks to the repro service crown, this is the only one I have I could actually feel safe to swim in!
    • I suppose the first question is have you got the correct replacement stem. If you've removed it in the setting position then you could try pressing the button while inserting the stem. Other than that it's a case of possible strip down to get to the setting lever.
    • The stem was already broken when I got the watch, so there was a piece already left in the movement, so I don’t what the setting was at when it broke! There’s still a broken piece left in the crown which i can’t get out! I just removed the broken piece left by the detent button as normal!
    • How did you remove the stem and what was the reason for removing it.
