deformed hair spring
Lubed up, back together (minus the one screw), and I'd say not a bad result! Going to give it a day or two to run in while I clean up the case and regulate it again, but off to a good start. -
So it runs and keeps good time even with that train wheel. You are lucky I would point out to the owner about the wheel, just in case at some point they take it to a different clock maker.
Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement. As they are screws to hold links it is possible they are false and do nothing. Already said photos are needed.
By watchweasol · Posted
Hi New. More of a get you out of a hole than a bodge. There is no substitute for a new coil.
