I’m in the process of servicing my first watch ever, after completing two levels of Mark’s course. I welcome tips :)
So far I have disassembled and done one cleaning. Next, I will use the ultrasonic and then will lubricate and reassemble. Fingers crossed!
7 hours ago, watchweasol said:
Hi SiZi      my pleasure we are all here to help where we can. Its what this site is all about  cheers.
Glad I'm here!
6 hours ago, Watchtime said:
really nice work for a 1st timer...well done...did you see Mark's comment about putting back the main spring by hand...:biggrin:
lol, yes, but it was too late! I didn’t have a wonder and wasn’t ready to wait several weeks for one to arrive (I live in India). So, this time won’t be best practice :)
6 hours ago, jackie01 said:
Congratulations. It's pleasant to see this work. Would you describe how you did cleaning process od the dial?
Thank you, and sure... first I used cotton buds to very gently wipe dirt off the dial face. Then, for the metal hour markers at 12,3,6,9 a little simichrome was used with a cotton bud. I had to be super gentle through the process.
Many people will disagree, but I find that it is ok to fit mainsprings by hand if you are careful. I still use a winder when it's easier though.
  • 2 years later...
Really curious to know what you did to get dial back to its former glory? There's quite a difference between "BEFORE" and "AFTER". Thanks!
On 9/8/2019 at 9:57 AM, SiZi said:
I managed to put the mainspring back by hand, and started assembling the watch.
A helpful tip for anyone looking at this discussion? I snipped out an image found up above a typical newbie mistake? People usually reassemble the watch in the opposite order they took apart. Usually what I'll notice is they put the pallet fork in right at the very beginning and that's a big mistake. Yes you can put it in but you don't have to. If you don't have the pallet fork in you can verify that the gear train spins. It makes it a lot easier to put the wheels back in if the pallet fork is not there. So typically you put it in just before you put the balance wheel in makes things a lot easier.
 This makes lots of sense.  When you have the fork in place and instal the barrel bridge next, you have missed the chance to verify the train running effortless and its back spin.
my opinion for the correct reasembly
1)barrel bridge
2)train wheel bridge
3) sec pinion with care a lot of 3rd wheels are damaged for this assembly
personaly i take a new clear oiler to hold them down(the pinion) to put on the bridge
4) pallet fork
5) balance
and good oiling and a bid of luck if you use the old mainspring
    • I also still use my cheap first set of screwdrivers. I replaced the blades of the smallest (0.6mm) with higher quality once I had bent a few of the originals, but beyond that I have been fine. Note though that I do not work on any remotely valuable watches and most of what I deal with are in a truly terrible state, watches that have been banging around in kitchen drawers or toolboxes. So my concern for screw head slot integrity and scratches is usually not very high.  As for a loupe - you won't need anything powerful for an ST36 that is new. You don't need to do close inspection of balance pivots because they will not be worn out, and a 3x or 5x loupe is perfectly sufficient to see the oiling. I don't have any microscope or powerful magnification of any sort. I just use cheap loupes. But again this would be different if I were working with more valuable watches. And if I had equipment to burnish pivots, then I would get a microscope to check my work.
    • I've recently switched over to using a x2.5 -x3 eyeglass for disassembly and some larger part assembly. It's interesting to see how accustomed and trained your eyes become to that way of working after using a microscope for years. And pick up and work at eyelevel when possible. Personally I would stick with and learn to use regular oilers efficiently.
    • I remember playing with asbestos wire insultaion when I was a kid (remember the cool fluffy white stuff?) and I've been breathing fine dust particles in my woodworking shop for years, so I'm probably toast either way, but I don't want any of this radioactive dust anywhere near my kids.
    • Its good to understand how and why demagnetisers work. These two pieces of text explain in basic terms how ferrous metal is affected by magnetism and why they can retain some of those properties.  The cheap demagnetiser is actually a magnetiser,but is used in a way that can remove the weak magnetic properties that a steel has gained through magnetic field exposure.  As steel is drawn further away from the device, the magnetic fields around it become progressively weaker and more -irregular- . This causes the disruption of the atomic and subatomic alignments within the steel that make it magnetised. So also moving the steel  through different orientations as its pulled away could actually improve that process. I still use my first cheap set of drivers, I notice very little difference in the way of feel between them and a set of preowned Bergeon I use, blade quality is more important. Tweezers have more variables, but again they don't have to be expensive to work well. My most used tweezers are my cheapest, but then I never use any pair that I haven't modified in some way.
