ETA cal. 2824-2 (17 jewels) disassembly/assembly
Where in the world are you? If you are in uk you can send to me and I will re pivot it , if in USA ask on NAWCC if elsewhere sorry can’t help.
I just had a look w/o luck... Here's a decent database too: https://www.emmywatch.com/db/movement/oris--581/
Hi! I'm Leo and so far I followed Mark's courses (great work Mark!) and as suggested I stripped and put together an ST36, so far twice. All good so far, except a flying click spring that I managed to find on the floor. Now it's time to think about cleaning and I'm considering carefully the different options. I live in an apartment in Stockholm. Ventilation is always on and windows can be opened, but still I would like to keep the family exposure to toxic fumes to a minimum. Also being able to drain the liquids in the sink sounds convenient. I don't have machines right now, but I could consider an ultrasonic or some spinning contraption maybe (chrono clean or similar, if it's not too big). So I thought I could try out a water and alcohol based system, using heptane only for the balance complete and the pallet fork. In my area I can procure easily 99% IPA, distilled water and generic Heptane. Then I usually order tools from Cousins, which does ship hazardous liquids to Sweden but it's very expensive to do so. I was wondering if such a mostly water-based system makes sense for me a beginner? I could pre-clean with IPA and pegwood, then clean with some water-based detergent, then rinse with tap water, then distilled water, then alcohol, then low over for drying maybe. And keep the heptane only for dipping the balance complete and pallets. Any advice as a safe detergent? Dish soap even? Or I checked at Cousins at it seems that the only non-hazardous product they sell is Elma EC90, which among other things is classified as safe to drain. Could that be a good choice? Re: the machine: should I be good starting by hand with these mostly safe liquids, of is it better to start off with an ultrasonic or something else? What's my current plan? After practicing with my ST36, I was thinking of servicing pocket watches first - I like hamilton railroad ones, maybe. Then if I succeed with those, try to service some seiko and sw200 wristwatches. Many thanks for any advice!
Probably - the movement is an old Oris 581 kif, so not rare or valuable, but I must say don’t see many of these on eBay. I see lots of other vintage oris calibres but I don’t know if any of the parts would be compatible. Is it possible to look up which Oris movements might have a compatible fourth wheel anywhere? Thanks I think it’s worth a try. Can you suggest what type of tube might be useful for doing this? I thought about trying a pin vice but that seems a bit clumsy.
