amplitude problem
watchweasol
Hi Guys watch weasol here from  St Combs Scotland. been repairing clocks and watches for many a year, now retired and still at it
but now I have a problem on a Omega 522 It had a broken  mainspring  which was replaced (GR) and re assembled problem is that
I cant get the amplitude up to 250 deg it is around 160 deg and running fast. I have cleaned the watch removed and cleaned balance
jewels and run up using a Horotec timer Lift angle = 49   Beat error = 1ms,   Any ideas or pointers would be appreiated.
thanks   Weasol
Hi Weasol, I had a similar problem a little while ago with low amplitude on an old Everite watch. I re-cleaned the pallets and pallet bearings in Acetone to completely remove all oil and re-assembled with NO lubrication to the pallet arbors. Result was a further approx 60deg balance amplitude. Old Hippy advised me to do this. I used 9010 the first time and I think that it is a bit sticky !!. Just saying.
I've said this many times, but those later Omegas (500 series onwards) have finer pivots are are more susceptible to suffering from the effects of dirty jewels as there is less torque going through the train.
However, you mentioned it runs fast, so I would also look very closely at the action of the hairspring to look for any irregularities. Could be bent or magnetised.
Is the amplitude the same DU and DD?
I can confirm this - see the thread "Omega 613 low amplitude solved. Don't forget to check this jewel is you have low amplitude".
A dirty balance hole jewel was enough to knock the amplitude down from 270 to 190 deg.
BTW there's no listing for 522 on Ranfft - do you mean 552 ?
Cheers guys food for thought there, I changed the balance complete in an effort to isolate the problem
and got the same result, maybe have a closer look at the pallet and jewels. sorry for the typo I meant a 552.  good advice as always will let you know the results when I get down to it got a few jobs to do. by the way its the same DU or DD. The finer pivots may be better running without oil, just a thought.
thanks   Weasol
Hi, it’s running fast because the amplitude is so low...
Cheers Kaz
There are so many possible causes, can you give any more info? Does the train have backlash with the pallet fork removed? Did you peg the jewels, especially the escape wheel and pallet fork jewels? With the fork out, does the balance oscillate freely and for some time? Are you sure you put the right mainspring in? Try removing the tension spring for the sweep seconds and see if amp goes up to eliminate that.
Hi Guys  Right got back to the job , removed the oscillator weight and associated bridge leaving a basic watch. remove the balance and pallet cleaned and reassembled dry (no lube) amplitude has increased
 but watch o scope reports a loss rating even though the regulator is fully advaned. The oscillations of the balance look good and again watch o scope reports 250deg. My horotec sensor wire broke so have no recourse to back checking  (Gremlins).
The train seems clear enough and has some reverse movement when manually operated . the mainspring was a GR from cousins for the 500 series omega so should be ok..
Will have to repair the sensor or get another.  happy days.  thanks for guide lines guys.
cheers  weasol
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
