amplitude problem
watchweasol
Hi Guys watch weasol here from  St Combs Scotland. been repairing clocks and watches for many a year, now retired and still at it
but now I have a problem on a Omega 522 It had a broken  mainspring  which was replaced (GR) and re assembled problem is that
I cant get the amplitude up to 250 deg it is around 160 deg and running fast. I have cleaned the watch removed and cleaned balance
jewels and run up using a Horotec timer Lift angle = 49   Beat error = 1ms,   Any ideas or pointers would be appreiated.
thanks   Weasol
Hi Weasol, I had a similar problem a little while ago with low amplitude on an old Everite watch. I re-cleaned the pallets and pallet bearings in Acetone to completely remove all oil and re-assembled with NO lubrication to the pallet arbors. Result was a further approx 60deg balance amplitude. Old Hippy advised me to do this. I used 9010 the first time and I think that it is a bit sticky !!. Just saying.
I've said this many times, but those later Omegas (500 series onwards) have finer pivots are are more susceptible to suffering from the effects of dirty jewels as there is less torque going through the train.
However, you mentioned it runs fast, so I would also look very closely at the action of the hairspring to look for any irregularities. Could be bent or magnetised.
Is the amplitude the same DU and DD?
I can confirm this - see the thread "Omega 613 low amplitude solved. Don't forget to check this jewel is you have low amplitude".
A dirty balance hole jewel was enough to knock the amplitude down from 270 to 190 deg.
BTW there's no listing for 522 on Ranfft - do you mean 552 ?
Cheers guys food for thought there, I changed the balance complete in an effort to isolate the problem
and got the same result, maybe have a closer look at the pallet and jewels. sorry for the typo I meant a 552.  good advice as always will let you know the results when I get down to it got a few jobs to do. by the way its the same DU or DD. The finer pivots may be better running without oil, just a thought.
thanks   Weasol
Hi, it’s running fast because the amplitude is so low...
Cheers Kaz
There are so many possible causes, can you give any more info? Does the train have backlash with the pallet fork removed? Did you peg the jewels, especially the escape wheel and pallet fork jewels? With the fork out, does the balance oscillate freely and for some time? Are you sure you put the right mainspring in? Try removing the tension spring for the sweep seconds and see if amp goes up to eliminate that.
Hi Guys  Right got back to the job , removed the oscillator weight and associated bridge leaving a basic watch. remove the balance and pallet cleaned and reassembled dry (no lube) amplitude has increased
 but watch o scope reports a loss rating even though the regulator is fully advaned. The oscillations of the balance look good and again watch o scope reports 250deg. My horotec sensor wire broke so have no recourse to back checking  (Gremlins).
The train seems clear enough and has some reverse movement when manually operated . the mainspring was a GR from cousins for the 500 series omega so should be ok..
Will have to repair the sensor or get another.  happy days.  thanks for guide lines guys.
cheers  weasol
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
