Hand setting tools and advice
AP1875
Currently working my way through the course, unfortunately reinstalling the hands is not covered in as much detail as removing them, so I just want to ask the members here for some advice.
My partner bought me a set of tools recently, included is a red block with a prong I can push down to mount the hands with several plastic adapters of varying sizes.
I tried installing the hands on my practice watch, it’s a cheap Panerai copy from Bangkok. When the minute hands gets to the seconds (at 9) it hits the seconds hand and stop the movement.
How do you know which adapter to use for the hands you are installing?
How do you know hard/far to push the hands down?
Any advice appreciated, thanks
I'm assuming this is the tool you are talking about.
For the second hand you use the adapter that is solid with no hole, for the hour and minute hand you need to use one with a hole in it big enough to clear the posts that the other hands, but no bigger so you are evenly pressing down on the hand you are fitting
Check that you have not slightly bent the hands removing them, especially the second hand
You want to press the hour hand down until the top of the hole in the hand is flush with the post you are fitting it on unless that will make the hand fowl the dial. The hour hand will generally fit parralel to the dial, but the minute and second hand can be fitted on their posts not perfectly square. Check each hand is parallel to the dial, if it is not figure out why. Have you bent the hand, is it not sitting on its post correctly leaving it at an angle?
Not much pressure is needed especially for the second hand.
Hi, yes that is the tool I have although I don’t have as many parts as the one you show.
So, for the minute hand the part I require needs to be able to slide over the canon pinion but rest on the pinion/loop at the end of the minute hand so I can push it down.
The part for the hour hand needs to be able to slide over the post of the hour wheel but rest on the hand pinion/loop of the hand.
Is that correct? I have a attachment that will slide over the canon pinion but don’t have one big enough to slide over the hour wheel.
Thanks
Just want to chip in that I use hand setting tools like these. I like them because they are flexible and can be slighted tilted if needed when pressing on the hands. Of course, the ideal is for the hands to be perfectly parallel with the dial, but being able to make a tiny adjustment can sometimes be helpful.
I don't understand what you mean by "rest on the pinion/loop at the...". I have limited experience (Vostok and Poljot movements and the Unitas 6498) but as far as I know, the minute and the hour hands are only held by friction on the cannon pinion and hour wheel. They don't "rest" on anything.
Edited by VWatchie
I’ll definitely check them out.
Do you know what size I’ll need for most wrist watches? 28xx 7750 3135 etc?
And do you know if my description above is what I need to do to install the hands correctly?
Thanks,
Thanks, I meant the tool. So as you say they are friction fitted to cannon pinion and hour wheel but does the tool work by being able to sit on the pinion/loop of the end of the hands but (the tool) also needs be big enough to slide over the canon pinion/hour post so you can push the hands down far enough. Sorry I hope what I mean is clear, quite hard for me to describe these things
Thanks,
I bought the hand setting tools I linked to and the size of them have covered all my needs so far. Your second question is more difficult to answer. This is how I have been doing it so far. Press down the hour hand as far as it goes without fouling the dial. Press down the minute hand as far as it goes without fouling the hour hand. Press on the seconds hand on its pivot without fouling the minute hand.
Oh, just realized I haven't tried these tools with the Unitas 6498/6497 (hands remains to be mounted), so I can't vouch for their size with the Unitas.
So when you’re doing an hour hand does the tool that you’re using slide over the post of the hour wheel?
The hole in the tool needs to be big enough to slide over the hour wheel post or canon pinion depending which hand you’re fitting?
You describe it perfectly! The tool needs to be able to press on the loop of the hands AND be able to slide over the cannon pinion and hour wheel!
Yes!
Yes!
7 minutes ago, AP1875 said:
Every other day I seem to need another tool....
And it will never end, also you will find you buy tools that are described to do one job and you use them for a different one.
My favourite tool for removing hands off watches are my Begeon hairspring leavers.
If you haven't already set yourself up an account on Cousins UK if you plan to get serious, also Eternal Tools in the UK are also worth looking at.
Do your research before buying tools as sometimes you can get away with the cheap Chinese tools, but other times you really need to buy the expensive ones. Don't go cheap on your tweezers or screwdrivers, also invest in a cheap 400 grit diamond sharpening plate to sharpen your screwdrivers and a cheap sharpening holder for the screwdrivers if you haven't already.
I’ve noticed that I’m beginning to enjoy some of my tools as much as my watches. Maybe I’ll die from starvation, but at least I’ll die happy holding my cannon pinion remover tool in my hands. :D
I also love my vintage cannon pinion remover.
But my favorite new tool is my Bergeon 30671.7 hand remover.
I haven't used it for removing hands, but it was perfect to remove the friction fit wheel on my Elgin Pioneer aircraft clock and I doubt I would of got it off any other way.
I also use the A-F brand hand setters similar to the ones shown in the eBay link. Bergeon makes them as well of course but these are an example of a tool where you don't need to spend a ton of money. It's just a bit of Delrin on the end of an aluminum tube... Get two sets and keep one stock and the other for modifying. Add a colored tape band to the modified ones* to tell them apart easily.
One trick I use is to hold the hand with a piece of rodico near the tip of the hand, and place it that way. I only use the tool for pressing once the hand is on the proper pinion. There is no better way to destroy the seconds hand pinion than to press it when it's not in perfect position... It can also collapse the bore of the seconds hand and then you have a problem... I like the look and idea of those fancy hand setting stands, but you still need to set the hand correctly in the first place. I guess one advantage is it ensures the hand is pressed perpendicular to the main plate.
*Note that I modified my hand setting tools, as I seem to end up doing to every tool, regardless of manufacturer. I used suitable drills to open up the small dimples in the ends of the tools for better clearance and additional depth. I like to just clear the canon pinion so that when I press the hour hand on, I am fully pressing the hand but also have a reference surface of the tool which will hit the top of the hour pinion, preventing me from pressing it too deep. With old printed dials, it's not a big deal, but more modern dials with applied indicies can be a big problem if you press the hands too far.
I also use levers to remove hands, rather than the "presto" tools. Often these old hands are worth more than many people pay for entire watches, so the less you manipulate them, the better. I use Bergeon levers but I still polished them further myself to make them "perfect". They had a very nice mirror polish to them coming in but I wanted to soften a few edges to avoid marks. I think I have since chipped one and I needed to address that as well. They are VERY hard steel...
Many tools that you puchase, even Bergeon need 'fettling'. Presto canon pinion remover is one example. Whilst trying to lift the canon pinion it reminded me of one of those cranes in an arcade and just slipped of, the grooves in each arm were too big. Needle file and 2 minutes and it works fine although it would probably have worked on a bigger watch. Hand levers are another example. When first purchased they are more akin to tyre levers but a dremel soon sorts it.
On ‎8‎/‎28‎/‎2018 at 5:12 PM, Tudor said:
I also use levers to remove hands, rather than the "presto" tools. (- - -) I use Bergeon levers but I still polished them further myself to make them "perfect". They had a very nice mirror polish to them coming in but I wanted to soften a few edges to avoid marks. I think I have since chipped one and I needed to address that as well. They are VERY hard steel...
If it's not too much trouble, can you tell us a bit about what you use to polish them and how? I'm thinking I could use some 3M lapping film, no? Perhaps, you have or can take a picture? My levers are cheap Indian levers from CousinsUK. They have served me well, but nothing is so good it can't be made better! ;)
Edited by VWatchie
  • 4 weeks later...
I Just use two tweezers.One to grip the hand, the other to push it down.hold the tips far enough a part so they are just slightly wider than the hole.After mounting the hour hand I rotate it to six o'clock.I then do the minute hand. It is my opinion that this is the most accurate way to do it because the hands are 180 degrees apart and any error will be most  obvious. I then rotate them several time to make sure they don't hit. With the watchrunning I mount the second hand.I press down with the blunt end of the tweezers.
Edited by yankeedog
wrong word
I prefer to set hands at "noon/midnight" so that you can see the tip of the minute hand is on the zero marker and there is exactly the same amount of hour hand exposed on either side.
I have heard of people using "3 o'clock" for setting hands too. With the hands directly on top of one another, you have the highest degree of accuracy possible- they are never closer than this at any point on the dial. It also allows you to evaluate the parallelism of the hands in relation to the dial surface.
I prefer to hold the hand with a piece of rodico- tweezers, even well groomed and polished ones, can scratch the hands. This is a particular concern with newer white gold hands. Then press with the plastic tip tools. Once the hand is set, I clean the surface thoroughly with Rodico before setting the next hand.
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
