Porcelain dials
Am I right in thinking that if there is a hairline crack, the watchface would be porcelain?
Also if an old watch face is faded would it be more likely to be enamel?
I have a family heirloom trench watch that I would like to explore one day to find any maker's marks but I think it may be a porcelain dial and I would hate to damage it if it's a bit tight coming off.
That's a really cool piece.
First: full disclosure- I've never restored a porcelain dial.
But, I had heard a rumor (or reads somewhere) that porcelain dials with cracks can be cleaned up in ultrasonic to remove the dirt from the crack and that alone makes then 99% invisible. I believe simple water was/is the solvent.
Further, I seem to recall a restoration powder of some sort that is used after cleaning to fill in larger cracks.
But either way, the cracks must be clean before you try to "repair" them, however that may be done.
Maybe old hippy has some pointers as he's been at this stuff for a lot longer than I have! Maybe even has some more useful first-hand experience to draw upon.
Thanks for the advice guys. I'm surprised at the ultrasonic, I would have thought the vibration would have opened up the crack.
On this one the crack is not visible with the naked eye but under magnification there is a slightly darker line running from 8 minutes past to the centre hole.
So am I right in thinking this is a porcelain dial?
I would say with almost certainty that it is an enamel dial, which means it will have a metal backing to which the enamel is baked onto. I would be amazed if it was porcelain, which does not have the metal backing (image a porcelain plate or vase - no metal backing - solid ceramic like substance) .
Thank you Michael, that clarifies it somewhat. I do believe when I took the movement out last time, the dial has a metal backing.
Thanks to all for the info.
I thought I would clarify this you're not going to see the metal on the backside of a enameled dial.  When enamel is baked on the metal it has a problem of having a different thermal expansion than the metal itself. This means that when it cools after being fired the enamel has a tendency to crack. To prevent that enamel is put on the backside of the dial to cancel out the different thermal expansion on the front side. For example this is a Hamilton pocket watch dial front and back. notice typical of American pocket watch dials the subsecond is recessed and is actually a separate  enameled dial soldered the main dial.
Pretty impressive that these hundred year old dials survive an ultrasonic bath. Brushing a modern dial can make me nervous!
Although I am still not 100% on ultrasonic. I feel like it could open up new cracks from all the vibration. Clearly people use it to great success but I learnt that it's good to be paranoid about damage in watchmaking.
From the old books I read, they suggest just using soap and water with some gentle scrubbing. If it was me, I'll do that.
I use the false teeth cleaning tablets, glass of cold water drop in the tablet then the dial and let it bubble away, dirst is removed from the crack and it’s gone! I was told to be careful about the numerals incase they didn’t have a laquer over them as they could be lifted off , I haven’t experienced this yet and have done qu a few
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
