Will not go face when down
Hello Mates,
Im working on a Seiko movment 7619-1020, and when I have  cleaned it and oiled it. And are doing some testing, and it runs good laying with face down, but when I flip it over, it will not gor good. And almost stop.
Some ideas where to start searching ??
31 minutes ago, jdm said:
Do you have a timegrapher picture of when it "runs good"?
First photo is face down, second face up.
I have got it to go, with face up, when suddenley, its slowers down ...and I have to flip it over and sort of start the balance wheel again. And the it pick ups speed, and gos normal.
It shows poor amplitude and pattern even when face down. So once you take it apart again you'll have to inspect very carefully balance jewels and pivots, especially cock side. Also replacing the mainspring could improve the situation.
1 hour ago, jdm said:
It shows poor amplitude and pattern even when face down. So once you take it apart again you'll have to inspect very carefully balance jewels especially cock side. Also replacing the mainspring could improve the situation.
I have allready found out that the main spring must be changed, but if Im going to inspect the jevel for the balance wheel cock side. What are the criteria for no go or what to be looking for, according to what??
That all parts that have friction has to look practically as new under a strong loupe.
And new looks like?    The hole must have nice and even ends, not jagged and the hole must be round not oval,,,,that kind of things or?
Have now taken out the main spring, open the  barrel and inspected, looks ok. Put the lid on, took on of my small and strong plier, og sort og winded it up by hand some turns. And it feels strong and good. Or can a main spring be bad even if it feels good??
Took out the jevel on the cock side, inspected in microscope. Looks like another jevels I have come a cross by doing service, dont know realy what I should be looking for??
Some with some good ideas?
Look for a worn spot or pit in the centre of the jewel.
But I still think you are most likely to have an oscillator problem as your rate varies significantly between DU and DD. How does the hairspring look?
One other quick thing to check is your balance end shake. This can affect the interface between the impulse pin and pallets in extreme cases, but is less likely to be an issue on a newer watch like this.
One thing I did not realise is that the second timegrapher photo only shows “good” amplitude because it is immediately when the watch is flipped over to DU.
In which case carry on looking for sources of friction such as the balance end stone, balance jewel hole (is it cracked?) and end shake.
Edited by rodabod
  • 2 months later...
Is one pivot shorter than the other?
At this point, you have no access to the mainplate jewel , incab, you should see the pivots just sticking out from the jewels when you remove the cabs one at a time.
What is the end shake?
My question for @jdm is, can you tell from the graph if the fork is hitting the roller plate?
The pivot at bridge is likely to be shrot, with it,s cab removed you should see pivot's tip appear and barely above the jewel hole.
A regular test now is to lift one side of the wheel see if the pivot slides out of the jewels.
  • Similar Content
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
