Sorry about the downtime today. Tried to do an upgrade due to there being a security issue with the current version. Unfortunately so many errors presented themselves I had to roll back to a backup.
It then still would not play ball as some CSS cache files would not load (causing a broken look on the pages).
Going through all my backups I found the broken files and restored them individually one-by-one.
All seems OK now - time for coffee :|
Will try an upgrade again in a few days, first need to work out why it failed.
About another 1.5 hour downtime again this morning (from 3am UK time) and managed to sort out all the problems.
The website is now upgraded and secure again.
If you were kicked off while I worked on it - I apologise.
No need to apologize and thank for that great place/forum.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Hi [mention=1]Mark[/mention]
Since your last update I can't connect with Tapatalk anymore
I have the latest version installed on the server.
I'm writing this with Tapatalk on my phone.
All seems fine.
Are you on the latest app version?
Anybody else having problems with Tapatalk?
Sent from my SM-G950F using Tapatalk
Hi again Mark.
I have :
1 - uninstalled and reinstalled Taptalk on both my Android Phone
2 - changed my password on watchrepairtalk
3 - tried to connect via Tapatalk
4 - failed with both phones
And no connection problems on the other forums via Tapatalk, only watchrepairtalk forum.
Edited by manodeoro
I even changed my email adress and password ... nothing worked
I really think the problem is with my account on this forum.
It's not a big problem as I still can connect with a computer but I'll be in vacation from 14/07 to 31/07 and I wont have access to a computer, only my phones.
So if you could try to see what's going wrong and solve the problem that would be really kind.
I've found that the specially tailored web interface for mobiles is so much better than Tapatalk, so I dropped the latter completely.
Faster, easier, full access to features and picture postings, no extra account needed. Thanks Invision developers.
Not easy to debug if I can't replicate your problem.
I will reinstall the plugin later and post when I've done this.
Tapatalk is a buggy piece of software and im getting tired of the malware aspect to be honest.
The IP board web interface is now very excellent so you do still have access via mobile.
If I create a new account and if it works on Tapatalk, do you think you can transfer my posts from the existing one to the new one ?
OK ... I've tried the IP board interface and it's OK
Edited by manodeoro
OK - I have completely deleted the Tapatalk plugin and re-installed.
Interestingly this broke my Tapatalk app and no threads would appear in the app on my phone. Closing and re-opening the app several times kicked it into shape and all seems well.
Give it another try if you can.
Working perfectly today [emoji4]
Thank you very much !!!
    • Many thanks for your answers: 1. I will clean both of them without risk 🙂 2. Both of the rotate inside their setting but they don't seem to come out. I will clean the cock (and the hole jewels) and I will see if they want to go out. I don't intend to force the setting pushing it out by any means. I only hope I don't need the dismantle the whole cock into all its components...! 3. I won't touch it. Only clean. I don't want to take risk... Thanks again!
    • By worn pivot, Do you mean short ?   A pivot is not short if balance spins freely on it. Dial up & dial down tests are good test for investigation, visual test alone doesn't suffice. A thorough test is free oscilation, which is best done when balance cock is adjusted with acceptable end shake. Balance settings on both side should be dismantled as they must be cleaned, pegged and inspected.  Stud & pivot & where spring leaves the collet are on one line, show entire coil please. Regs
    • 1. I think the pivots look pretty good and I wouldn't worry about wear. 2. Yes, I think the hole jewels should come out for cleaning, complete with their spring setting. I don't have experience with Rolex but I've seen this spring type setting in another movement. They may be stuck in with old dried oil. 3. Yes, I think the overcoil is out of shape.
    • Yes, I'm looking at this option. I have a good friend from childhood who happens to be a goldsmith, and he would certainly be able to tackle the second hole to my specifications. I usually avoid this path because, since he deals with gold pieces, every time he stops to help me with "frugal" parts, he is objectively losing money. I agree with you. Even though I couldn't justify paying this much for the set (they only sell the whole set or the sole case tube), I understand the price tag. The trouble with this particular stem set is that the most common use case for it is the Technos Skydiver, a watch whose price certainly justifies 220 USD for a brand-new stem set.   I have messaged them only on the surface, without specifying my needs. They already stated that they don't sell the single female part, only the full set. What I still don't get is the need for a second hole. Is it supposed to be some sort of regulation, meaning that I can fit the head of the male part in any of the two holes to adjust the pressure of the spring? Does this mean that a single-hole female part has a chance to work with my setup? I'll later test this hypothesis while continuing the assembly of the movement. Some photos are attached. Can you judge this bracelet? It was dirt cheap (4 USD), genuine leather, wife's choice. I have just realized my dial is upside down. lol
    • Hello from chilly Brazil! I just bought a couple of watches and this watch came with them. While perhaps not worth much I'd like to try to find out something about it. Googling comes up with with the name Gerald Genta, and I see from internet searches he's made some nice designs (perhaps an understatement)! Also some cartoon designs but I can't find anything like this anywhere, so most likely not his!  Googling Royama I see that some famous people liked his watches and also the Royama watches. Two questions; 1. Can anybody tell me anything about this watch and its background? 2. How to get the base off to let down the main spring which is fully wound. I gently tried prying it but nothing, I see there is a button but have no idea if it is functional for removing the back or anything else. Screwed back maybe? I really don't want to break the back or the watch with too much pressure and haven't looked up the properties of Grilamid!   Probably not much of a watch but it peaked my curiosity and I hope somebody might be able to help? The auctioneer sold it as a psychedelic acrylic 1960/70 Royama watch overwound! All the best...Jules
