Screwdrivers Choices
Hello Everyone,
look for some advice on getting a screwdriver set to service watches with.
I first fought a $14 screwdriver set off of Amazon. First use the bit falls out of it. First use it bends. There was one screw none of the screwdrivers would fit to unscrew the screw in the watch I was learning on.
I returned that set and bought a professional set for $45 dollars.
I ran in to the same problem the smallest driver could not unscrew the screw and kept slipping out of the head of the screw. I tried larger size. It seems the tips are not fitting in to the head well enough.
I put to much pressure on the screwdriver and the shaft of the screwdriver snapped off while bouncing off my face,. Lol
I am glad I had the magnifying glasses on.
not sure if I am doing something wrong or I bought bad screwdriver set.
most likely it’s both,.. ?
where to buy the correct screwdriver set and what should the cost normally be?
I really thought the $45 set was professional set
Thanks
Link to post
  • Replies 206
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
You need to dress your driver of proper width, to the proper thickness.    They all tend to get thicker as they get wider, to handle the torque.
Hi ro63rto,   If the blades are straight, aligned and firm and remain that way when you fit Bergeon blades to them (better quality steel, not what they usually have which can scratch and damage the
This may sound like a silly question, but have you tried sharpening the existing ones?
Posted Images
44 minutes ago, Sidney said:
Hello Everyone,
Good day,
Here is huge selection:
https://www.cousinsuk.com/category/screwdrivers-individual
I never buy a set, but rather individual screwdrivers based on my needs: 0.5mm, 0.8, 1.00, 1.20, 1.40 ? (almost a set).
Any 2.50 GBP screwdriver from the link above will be fine for your needs. Just make sure to use screwdrivers according to the size of the screw head. If you use 0.5mm blade on 1.00mm screw head - you will damage both, the screwdriver and the screw. If you use 1.2mm screwdriver you will shave the metal around the screw head - also not desirable..
Link to post
Hi All,
Has anyone ever worked with these set/brand of Horia screw drivers? They seem to be swiss like Horotec but I'm not sure. I've never seen these and was wondering of they are a good buy for 79.95 USD. from Cas-Ker Co.
Blades are firmly held by set screw. Sizes .60 .80 1.00 1.20 1.40 1.60 2.00 and 2.50mm. Swivel ball bearing heads and knurled handles. Space-saving stable stand is angled forward for ease of selection.
any and all help is appreciated.
Link to post
Hi   Horotec do supply some good well made tools so there is no reason to suppose their screwdrivers are any different,  are the Conventional blade or the "T" blade variety, If so you will need to get hold of their cylnder sharpener to keep them dressed they aren't cheap pic attached
Link to post
I own one. It is a great tool but it’s expensive. After re- shaping the screwdriver tips to a T shape it definitely grips the screw head firmer with less chance of a slip.
Link to post
    • I've been working on an 8-day clock. The dial is decently large, but the actual movement is similar to an oversized pocket watch. The only markings I've been able to find are "Sandoz" on the dial, and on the barrel bridge: An "M" with emphasized serifs "15 Fifteen Jewels", "3 Three Adjustments", and "Made in Switzerland" The serial number 403250 While working on it, the click spring went *ping* into oblivion, and despite my best efforts and strongest magnets, I haven't been able to find it again. At this point, I'm looking to replace it. However, just going off the above markings, I haven't been able to find any information about the movement classification or caliber in order to find a proper replacement. Since it's a click spring, I'm not too concerned about getting an exact replacement just so long as it applies pressure to the click. The original was just a simple spring consisting of a single U-bend and fit into a channel 8.4mm long, 2.9mm wide, and 0.54mm deep. How would I go about finding more information on this movement in order to get a proper spring? Or just search for springs that have the right shape and dimensions?
    • Yes it can;  perhaps impulse jewel can't enter the fork horn, if the shock has  knocked a pallet jewel out of alighnment or bent a pivot. Remove the two black screws then the automatic device, loosen the cock screw by couple turns, raise the bridge just enough to pass the impulse jewel over the fork so to get impulse jewel inside the horn, tighten cock screw. It will run, however , might get stuck again if pallet jewels have got misaligned or a pivot has got bent.
    • A little uninspiring.  It does run though...kinda.
    • I decided to find a knew winding pinion for my Vulcain.  I see some wear on the one I have.  I have the spec sheet on the Vulcain 120 and identified the part as #1246.  I searched around and found scotchwatch.com had one.  $45.  I really want it, so I bought it.  Meanwhile, I continued my search and found a part with a different part number (410) on Northern Watch & Clock Supplies in the UK.  It was just a couple of pounds, so I bought it. Later I looked at the invoice from scotchwatch.com and see that the part I bought is 1246 (410), so I think the part has two numbers.  Well, we will see when they arrive.  On part cost 20x the other one.  I am not complaining...as I am glad that someone takes the effort to maintain an inventory for budding watchmakers like myself.  I just think it is interesting. Learning new things every day.
    • Thank you for your introduction and welcome to this friendly forum. A nice looking watch you are wearing.
