But you are all missing the point. The final mark of quality is that the blades should be dressed with the Horotec or Bergeon twin roller sharpener that produces parallel faces at the blade end. $$$$$
It does make a lovely job Colin, but not required unless you just have to have hollow ground blades.
Geo, didn't you notice the touch of irony?
I find that with a little care on a single round-section stone, dressing each side in turn, I can do the job just as well for twopence.
Colin.
As others have said, it's the quality of the blades that's the most important factor.
However, I decided to treat myself to a recent birthday present with a set of VOH screwdrivers, they are an absolute pleasure to use (and have a nicer feel than any Bergeon, Horotec or AF that I've used).
post-1141-0-93290200-1446762517_thumb.jp
But I also use various other screwdrivers where one of the VOHs isn't suitable, these are mostly tailored and dressed for individual tasks, here are about half of them  :biggrin:
And also as others have said, shaping and finishing the blades is critical to maintaining good tools and reducing the risk of damage to scres and other delicate bits.
post-1141-0-25424600-1446762709_thumb.jp
Edited by JimInOz
Hi guys! Does anybody know were I can buy VOH screwdrivers in the uk?
I've tried all over but I've had no joy!
I'm looking for the 2.5mm screwdriver,
Cheers guys [emoji2]
Hi clockboy, I'm just trying to complete my set I bought a couple of years ago off swisswatchtool the screwdrivers are fantastic mate! I just need the 2.5mm to complete the set!
I suppose this is a "sentimental" 2.5 mm screwdriver issue, otherwise I would get a different brand, readily available from your preferred -- read expensive -- brands, whichever one you choose. The nice thing about screwdrivers is that there are tips available separately so maybe, just maybe a VOH for say, 2.0mm tips, with a little elbow grease may "host" a 2.5mm tip...of course the color code will be screwed up...pardon the pun.  :)
In any case, I hope you find what you are looking for.
Cheers,
Bob
Thanks Bob, I'll keep looking for now mate! I've just been looking at the bergeon 30081-250 nice screwdriver at a good price! [emoji2]
Sorry to tell you bosstaki, "good price" and "bergeon" are mutually exclusive words! :) I wish you luck in your search, if I find something I'll post it here.
Cheers,
Bob
They are as good as Bergeon and the tips fit each other. Some people are partial to them rather than Bergeon. Also they offer different models just like most everybody else. Honestly, I made my set a little bit of everyone so I could compare and am using mostly the cheaper Bergeon one (about $100 set of 9). All that said, it is mostly out of habit rather than because of niceties. The rubber covered ones are probably better to my taste but somehow they still get second choice. Go figure! In the end it just a matter of habit and individual preferences...at that level of quality.
Hope it helps your decision,
Cheers,
Bob
I'd hold out for a VOH and only get a cheapy if you really need a 250.
I think it would make you grit your teeth every time you saw the **BLEEP** child among your VOH beauties.
I know it would me.
Best of luck with your hunt.
Cheers
Jim
post-1141-0-21308000-1447717269_thumb.jp
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
