I have trouble removing a pair of stubborn vintage spring bars that are double or single shoulder. (not sure...)
Any tips ? I don't want to ruin the bracelet nor the spring bars.
I can move the large tube from side to side a little bit but can't pry the first (or maybe it's the second) shoulder.
Was thinking of gluing something on one of the shoulders and pulling it sideways to see if it'll release.
Slip a piece of paper or business card stock between the body and bracelet/strap then place a decent size screwdriver in the same gap, close to one end and apply pressure to break the end off of the spring bar. The card stock is there to prevent marking up the body.
Sent from my iPad using Tapatalk Pro
Judging by the amount of DNA there, it's probably glued itself in place.
+ 1 on breaking the springbar.
Or you could try suspending the watch upright over an ultrasonic to try and dislodge said DNA?
I managed to come up with my own solution and I saved the bracelet and spring bars which are in good shape.
I decided to try and run some dental floss through the spring bar shoulder and case and it worked a bit. I was then able to barely insert the tool and pry it off. It took a few tries but it eventually worked on both sides.
When I ran the dental floss through the spring bar and case I also tried making a knot but it didn't get all the way in, still it worked.
I know but these looked like the original ones for the watch and I like to preserve as much as possible about a time piece. :)
  • Confused 1
strip the rest of the case and put it in the wash. its normally 'old man funk' that has gummed up the spring bars and a wash will move it and allow the spring bars to move again.
When breaking the spring bars be conscious of the case material.  Stainless Steel is fine but on base metal plated cases you may damage the lugs, especially is the band is a close fit around the springbar.
I had to do this on a Stainless Steel case once and the tip of the spring bar refused to come out.  Usually a round in the ultrasonic cleaner will rattle it loose but on this particular one I had to superglue it in and use a drill bit to grind it out. Without superglue, the remnants of the springbar would just spin.
Anilv
can you save the band ?   it is a good procedure though!
"the old man funk"  is best removed by a high quality "penetrating oil.  vin
Anilv
vintage watches often have "pot metal" cases that are plated over.   be careful,  the case breaks easly!
If you pry at the edge of the band, ie near the case, you may not damage the band but you may damage the case and/or lugs. Conversely, prying in the middle of the band may distort the band a bit but is safer for the case.
In the case of the original pic posted by the thread starter, I would probably break the spring bar by forcing a screwdriver into the gap in the band itself, not in between the band and case(see arrow). IMO this would be cause the least damage.
Anilv
Edited by anilv
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
