Eta Caliber 2540 Complete Service Walkthrough
I think I would use a spray on oil for springs.
By LittleWatchShop · Posted
Sure, but that means you remove the crown, add the extender, install the crown...only while on the bench. Is that worth the effort? -
I had to squeeze the insert in which is ok. The movement size is slightly reduced. One negative...you cannot wind or set the watch while in this holder. -
If you tend to be a little heavy handed then heres something that might help you to prevent cap jewel loses if you have some spare tweezers. File a round into each of the tips so you can grip a capstone or chaton while oiling or moving them around. Instead of filing along the length, angle file the tips first then file the rounds perpendicular to the angle. This way the tweezers wont get in the way of the oiler. Choose an angle that suits your natural hand grip position. The tweezers can now grip round parts on four sides Instead of two that often flip that part away.
