Esser Watch Case Opener
jdrichard
Although I have not seen one of these I can see how it works. It is for screw back cases. The tabs are for the different  slot sizes in the case back and fit into the part (the bottom right of you picture).Then you turn it over and adjust the distance required then turn the whole unit to undo the case back. I guess the other part is a clamp to hold the watch case if a tight one is being undone.
PS There was one on eBay SOLD & it shows instructions.
59a7bbbe3fd4f_ScreenShot2017-08-31at08_32_53.png.1f8a3d8e02f97c631e30a36e97cbd29b.png
Did not show instructions??
  • 1 year later...
Here is an auction with the instructions list on it.
https://www.liveauctioneers.com/item/16079885_esser-watch-tool-made-in-switzerland#&gid=1&pid=2
and they have one on eBay for the next three days, under this title: Vintage Swiss watch case opener holder tool watchmaker ESSER movement adjustable
And a picture from the liveauctioneers site from 20130
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
