In order to clean the strap of my wife's Rotary watch I need to remove the winder.
I've located what I think is the area that I need to work on (see attached pics).  There is an arrow pointing to a lever that moves when the winder mechanism is pulled out.  There is also a post with a dimple (there's probably a better technical term!) between this and the winder.
Should I be able to remove the winder by 1) moving the lever (and from which position) ... or 2) pressing on the post with the dimple?
Any help gratefully received before I damage a watch of sentimental value.
Many thanks
Tim
Hi Tim
the post with a dimple that you are referring to is called the setting lever and in this watch it is a spring push type (there are others that are screw type). You should be able to remove the stem by pressing the setting lever and pulling out the stem at the same time.
See this previous post from Mark on the same:
I think you will find the dimple/recess to press is inside the hole with the arrow. Look with magnification and as you move the stem you will see it & just press with a pin/prodder.
Don't press it too hard/far or it will get stuck. I sometimes press buttons like these with something wider than the button itself, like a screwdriver, as this limits how far it can depress. I usually release the stem from the "normal" stem position, ie. not in time setting position. Some Seikos require stems to be released in specific positions.
I've had/have one or two Rotary watches (with Hattori movements) that only allow you to see the push position through the hole when the stem is in the optimal position for removal...0/I/II, etc...very clever idea.
  • Similar Content
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
