Hello all from NW FL.
I just found the site today so I joined to learn a bit more about my new hobby. I have about 20 watches, a 4 watch winder, some tools and a curiosity about what I have on my wrist at various times. I like mechanical things so going from fixing my cars in years past, to working with machines making precision parts. I'm right at retirement age and slowing my life down to a low roar, trying to anyway. I bought a batch of watches to get the one I had years ago. I want to swap cases, hands and faces. I worked on a friends electric watch to see if I could get it running. Ended up buying her a new one. She is bigger than me... Not that I'm small, just sensible.
Thank y'all very kindly. I feel so proud to be a part of such a warm and friendly group. I have seen Mark's videos and they are very instructive and informative. His new shop is really nice. Perhaps my journey form macro/maintenance to micro/maintenance will be just as rewarding.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
