Watch of Today
mk3
2 hours ago, Cad101 said:
3 nice Helvetia's in a week ,....not bad . I went searching when you posted the Cal 64 .
The reply feature doesn't seem to be working properly ,.. But to answer your question , Yes I did . I'm watching about 3 offerings . I sent a question to one seller because the shipping calculator isn't working for my zip code .
In addition to my collection, another Vostok with a repaired 2416b movement. Current Beat Error 0.1 ms and a daily rate - 1 s/d. The dial is not where I go wild about, however, it's the first white dial I get black-hands to work clearly visible. The 2nd hand housing is of a Komandirskie which takes the thicker 2416b automatic movement. When time, I may give the case a Nickel re-plating due to some marks / scratches........
1 hour ago, GeorgeClarkson said:
And now something completely different from what we have been seeing here... A Slava Woman's wrist watch with 17 jewels. Still needing a service, but working well...
Very clean looking . It looks like a machine . No double mainspring on this little Slava I see .  Made for export with the English writing .
Can I have your dial someone gave mine a good scrubbing and finding a replacement is like trying to find the holy grail.
56 minutes ago, GeorgeClarkson said:
This morning I was wearing this Seiko Automatic Sportsmatic on a Nato Strap...
Edited by Cad101
    • the arbor square out of place and mainspring thickness/height is what I would double check on this model....
    • Hello and welcome from Leeds.
    • For larger or longer components I have a home made demagnetiser, a old central heating pump with the rotor removed, works well.
    • I agree - I use a magnetometer app on my iPad. A few years ago, I did invest in the Elma version of this demagnetiser. I have a background in electronics and when I cracked the unit open to explore it, I was very impressed - and reassured - by the careful attention given to the design and the quality of construction and quality of materials.  It will out-live me, and not because of any shock hazard 🙂  I find it very reliable for demagentizing watch movements, but for tools, especially elongated tools like tweezers and screwdrivers, they need to be done in sections, a couple of centimetres at a time.  I always also repeat the demagentising process several times with the object (usually a movement) oriented in several different planes - horizontally at 0 and 90 degrees and vertically.  Checking on the magnetometer app, the movement is effectively degaussed and I’ve not yet had to repeat the process. Just laying the movement horizontally and giving it a single shot sometimes works, but often doesn’t, hence my process above.  Using a compass, I doubt I’d ever know whether the process was effective or not.  The magnetometer is much more sensitive. I still use the Lepsi app, which was available for free, but which I don’t think is  available on the App Store any more.
    • Hello everyone, I have just started on my  watch repair journey. Many mistakes …pinging springs and lost pallet forks !! My great Uncle was a clock maker with a royal warrant  and his ancestor stated the first hall in London so hopefully some thing rubs off . Looking forward to following the  topics on this forum
