Watch of Today
mk3
15 hours ago, AndyHull said:
I thought to myself, "That is a very striking watch.", so much so that I did a little digging around.
I wasn't aware of the history so this was an interesting read.
https://wornandwound.com/review/zodiac-super-sea-wolf-68-review/
Zodiac has a very rich history. At one time zodiac divers were in competition with Rolex. The worn and wound article was great thanks!
The 99p Avia quartz went back on its own band today.
When I cleaned up the watch initially, I put it on a new band, as the one it came on was a bit grubby, however the original is a very nice, fairly high quality band and suits the watch, so I gave it the leather cleaning treatment.
This consisted of steeping it in a mix of white vinegar some disinfectant and a little detergent, and giving it a good scrub with a toothbrush.
The initial cleaning solution was then replaced with fresh, and the band was left to soak for a few hours. This allowed the vinegar to "tenderize" the collagen in the leather gently, softening it up. Next it was dried on a radiator overnight, sandwiched between sheets of  kitchen roll, and pressed flat with a couple of scraps of plywood, with a weight placed on top.
Finally the sued side was freshened up with a tiny amount of sued cleaner. Not enough to make it greasy, just enough to make it feel new. The top surface sheen was restotored with an equally tiny rubbing of silicon grease.
The result is a strap that looks like it just came out of the packet, and smells fresh and new.
This also frees up the replacement band for one of my Timex Automatics.
Today I'm sporting a textured dial Vostok 2614.2H based Soviet era Sekonda.
The 26XX is relatively easy to work with, and almost indestructible,  which is just as well as this one had quite a number of issues.
Fixed and scrubbed up, and with that textured dial, it exudes classical dress watch charm.
I've been thinking about getting a Russian watch myself. Nice piece Andy.
12 hours ago, AndyHull said:
Thanks. :biggrin:
A small correction to my earlier post,  it is a Poljot 2614.2H, not a Vostok.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Poljot_2614_2H
Anyone considering getting a Russian watch , Should get a Russian watch  I have had good luck with the raketa 2609ha but not so much with the 2609, I also have had better luck with the vostok 2209 vs the 2409.
Thanks for the advise!
As for the Slava,they are ok, but they seem to have weak balance staffs .Stay away from the day/date slava , overly complicated,engineered like they were trying to avoid patent infringement.Poljots can be good runners, but they seem to have poor metalurgy in the keyless works.
Something a little more refined today (not a 404 club member obviously, although I picked it up a while back before the 404 club started, and it cost me almost exactly the same as you would currently pay for a new "Starking" dress watch).
It does have a couple of minor nicks on the edge of the crystal, and a few minor scratches on the case, and the strap it is on currently is not the correct size, but other than that, it 'aint half bad.
Don't get me wrong, the Starking is not a bad watch for the money, but I know which I would rather have.
Edited by AndyHull
It's a very elegant watch. The crown reminds me of Cartier.
Another bit of old GDR nonsense, this 1950s UMF, liberated last week from the dark recesses of a tiny bric-a-brac shop in a Central European capital.
Runs on a surprisingly large (12.5’’’) Thiel/UMF 54-31, an agricultural movement and totally unacquainted with any jewels whatsoever.
Regards.
Just went to a wedding and decided to wear my vintage Heuer Ref. 73473, circa 1971-72. This watch is very unusual when compared to other Heuers, and not many made. But interestingly not very sought after by Heuer collectors. As for me, I love the Classic 70's look. It is powered by the Valjoux  7734 and fitted on a vintage beads and rice bracelet.
Edited by JasonND
You can never have too much Sekonda...
.. but I think this comes close.
Not sure of the caliber, it may be Russian, I'm no expert. Someone here may know.
It does have jewels, and it does have screws, so it isn't a cheap modern Chinese disposable, which is just as well, as it grunchy and crunchy when I first pulled out the crown and tried to turn the hands.
I didn't go overboard, just a little lighter fluid, a quick out and back in with the gears, and a tiny spot of oil, and now it is running fine and quiet as a mouse.
It has a bit of an excess of bling, especially now that it has been cleaned and polished, but is also very well built, and the strap is a work of art. When laid flat, you cannot see the joins.
It is a gents sized watch, but not something I would generally wear. Interesting none the less.
Another freebie picked up in a batch of stuff with one watch that I actually wanted, joins the Russian contingent of the 404 club.
Its a Timex Automatic TV face day today. A slightly strange one this, it appears to be a Dundee mechanism, french case (this is stamped clearly on the inside of the case back), but the outside of the case back states "Assembled in Taiwan", so probably an early to mid eighties watch, from the period when the Dundee factory was going through a bit of an upheaval. I must confess,  I wasn't paying attention when I cleaned it, so I didn't take a note or picture of the dial number.
The thing got a quick ' Duncan Slunge™ ' Timex service, and a great deal of polishing and cleaning, and is now running nicely. I'll take it a apart again and photograph the dial, when I've finished restoring the band and am ready to put it all back together.
Its original factory fitted Timex steel band is still in the process of getting cleaned and polished, so I popped the watch on a new old stock embossed real leather band, for that late seventies early eighties vibe.
Don't worry, that date works fine, it is just in the process of changing.
Edited by AndyHull
This rather forlorn looking thing is a Waltham. The logo was so poorly printed that it washed right off when I cleaned the dial.It came with an AS1686 with a rusty keyless works,which I swapped out with one previously serviced.the spiedel band came with the watch it has a '63 production date. I had to remove 5 links. The previous owner must have been a pretty large man.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 at 20° C) than 9504 (305 at 20°). The viscosity of Molykote DX is 285-315 at -25° to +125° C.
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
