Aloha Watch Fans , ...I've been pretty busy for the last couple of months and haven't posted any of my watches lately .
I'd like to remedy that by sharing a couple of Heuer and Tag Heuer chronographs from my collection .
!st off is this Heuer by Tag Heuer Monaco Chronograph . The model # is CS2111 and is what is called a re-issue or re-edition of the classic Monaco brought to fame by Steve McQueen's Blue Face version in the movie " Le Mans'....
Some tidbits about the watch...
http://www.timeandwatches.com/p/history-of-tag-heuer-monaco.html
https://www.calibre11.com/tag-heuer-monaco-re-edition/
The watch....
The next watch I would like to share is this Hefty Tag Heuer Carrera Caliber 16 . This watch is powered by a Valjoux 7750 . When I first got the watch it was in need of a service highlighted by the fact that when I hand wound it  , the oscillating weight would also spin causing a drag on the winding stem and causing the watch to wobble . I serviced it and am happy to report that it is purring like a kitten .
  This watch features a portrait of race car driver Juan Manual Fangio On the case Back .
I hope you enjoyed looking at these watches as much as I do .....Thanks , Louis
Another NOS Benrus..same as the stainless steel version I posted earlier. I purchased a lot of 19 NOS Benrus watches and I'm slowly getting them back in running order. They've been sitting around in their original factory shipping box for over 40 years. Most had broken crystals and some had calendar issues but they all seem to just need a good service to get running correctly... They'll keep me busy for a good while!:blink:
9 hours ago, ro63rto said:
Today is one from the USSR
Still have to re-lume it though.
Sent from my Honor 5c
Ok, I need your watch! I have this unique Day date dial movement combination. I need to find a case for it and yours has the exact dial shape that I've been looking for! It's kind of unique since it has a full day display and date on the same line..
Just got this 7a38-702a back fully serviced from George @ OnlyVintageWatches in Berlin and all new gaskets all the way from Adrian @ VTA. Thanks to both [emoji106]
If this watch looks familiar it's made up of a bunch of homage pieces and parts.. a Tudor black Bay case, a jaeger-lecoultre master compressor dial and hands, and a Rolex Submariner ceramic bezel.. none of it fit together out of the box I had to do a lot of Machining and modifying to get everything to fit together. Even the movement, it is a ETA 2834 with the day wheel removed and the expansion ring for the 13.5 line size..
I finally latched onto a nice Accutron "Woody " after making several attempts in the past .
I can honestly say that I really like this 218 Accutron , probably as much as my 214 Astronaut .
597c16da9027b_ScreenShot2017-07-28at6_56_43PM.png.9872ecd170d31d383d74a2ca9b423081.png
597c16f26890f_ScreenShot2017-07-28at6_57_39PM.thumb.png.81ec82098240f9ab20042195a2477563.png
  • Like 5
I have been wearing this really nice Seiko SRPA21 PADI Turtle Limited Edition I just got....Love it....
598e6db23f401_ScreenShot2017-08-11at4_42_46PM.png.cad5e5c525b0deeb6d0d7ce1e2f923f7.png
598e6dc8bc779_ScreenShot2017-08-11at4_43_56PM.thumb.png.ee79ac06d8f4f330a6a2cd838a56fa97.png
I have attached a link to a review of this beauty...
I have also recently picked up this 1949 Hamilton "Franklin" . Excellent refinish done to this watch , It looks new . Also , it comes serviced by a 3rd generation watchmaker and has a 1 year warranty .
598e70b87164a_ScreenShot2017-08-11at5_05_10PM.png.a71175315ffe921b600f3769b843a292.png
    • Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge. Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
