Watches of the day, thanks to my wife for the display case, a fantastic Christmas gift. Seiko 7006-8002 1971, Orient Star modern semi skeleton, Ricoh R61 70s, Seiko Kinetic 2004, Tissot Swissmatic, Seiko Premier quartz.
Hope everyone had a peaceful and enjoyable Christmas with family and friends and re-established what makes us human during these strange times. So what watch to wear today: my Glycine SST or my trusty Amphibia...20201227_103135.thumb.jpg.91adb0ed758e40a8a2c3e1461c409c98.jpg
Great looking watches and very well organized work bench! ?
25 minutes ago, Poljot said:
Your ordinary Pallet Fork that you see every day in modern watches (NOT) ?
Moser - approximately 130 year old.
Design inspired by alien visitations...
Counterpoised levers are so rare.  And that is a pretty one.
On 12/28/2020 at 9:46 AM, Tudor said:
I like the 24-hour Glycine.
it was my father-in-law's watch. he was a pilot and aerospace engineer. serviced it and runs like a champ. it's got an interesting setting hack. it's a hair-like spring that pops out between the 2 and 4 on the nighttime dial that stops the sweep hand when you pull out the crown to set the time. diameter of a human hair, made of spring steel.  upper crown sets the 24 hour dial. can't find a crystal for it though, to fix the crack. I have the wooden box, tags, band, everything it came with. very comfy to wear. It's called "the Pumpkin." Don't wear it too often.
thank you but the bench is a perpetual, never-ending disaster area! all it takes is one watch...instant mess.
This pallet fork is poised in all positions of the watch. Looks so "out of this world" ?
what in the....it's Pallet Fork man! ?
  • Haha 2
You should see my desk now... It's a very well organized MESS, but it's my mess and i like it better than "everything is in order" ? I know where each part is ?
Have to order three new mainsprings and realized that CousinsUK doesn't carry what I need. Now recalculating and compromising based on what they've got.
yeah, this is true. sometimes when I'm overwhelmed, I'll sit back, take a breath, and look out over the vastness of MY mess and think, "Yeah. I did this. I kinda like it this way."
and thats that.
i've got two balance staffs coming, and a K & D #50 staff remover on it's way. The remover is coming from the UK. Delving deeper into the world of balance staffs!  what mainsprings you looking for?
and thats that.
Some say that "staff removing" is done easier & safer using a lathe or a similar small gadget.
I no longer know what i am looking for as what i was looking for initially was declared obsolete.. Every approach, every formula, and every catalogue is giving me either NOTHING or conflicting information. Perhaps I am overthinking it, but when you need three different mainsprings which are not too weak and not too strong ? you can easily get a headache. Looking for swiss hook mainsprings in 2.7 x 0.22 or 2.8 x 0.22 ranges. Also need 2.9 x 0.21 (or 0.22) LoL
3 hours ago, Poljot said:
Where did this come from?
From the Hampden I finally completed. I had asked awhile ago if anyone had ever seen one like this. Called a moustache.
So I've heard. Unfortunately, I have neither. Maybe some day. Until then this is as far as I've gotten. I think I've seen the similar small gadget, but not in action. I'd like to find one, and see how it works.
Today, some German pin lever action, in the shape of a Kienzle "Markant" mechanische herren "Strapazier-Armbanduhr", probably 1960s or thereabouts.
It is relatively small for a "Herren" (mens) sized watch, with 16mm lugs. Given the somewhat "industrial" construction and the fact that it is still going strong I think it meets the claim of being a  "Strapazier-Armbanduhr" (hard wearing wrist watch).
Edited by AndyHull
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
