Roller adjusting tweezers.Bergeon 4852
clockboy
Some movements have no beat adjustment arm so what I do is move the hairspring collet to achieve  beat. However this has some dangers involved & yesterday I slipped and clobbered a hairspring. The hairspring was repaired but I thought maybe it would be better & safer to just move the roller jewel table. However I could not get it to move it with pliers or tweezers.
I found this item and was wondering if any of you guys have one and are they any good. Bergeon 4852.
589c1f275a999_ScreenShot2017-02-09at07_44_17.png.2150a60507155ca0b136bb8006bf5f44.png
I suppose a clarification is needed what sort a roller tables are we discussing here? I spent a lot of time working on American pocket watches so I'm going to answer from that point of view versus a modern Swiss roller table as it's a little bit different and it probably can be safely rotated but there's a minor technical issue.
American pocket watch roller tables are normally made out of steel occasionally brass or something similar to that. they friction on very tight. If they have a safety roller it's usually a separate roller. So both of them would have to be rotated to be in alignment. There's a danger of rotating these they might actually pop off depending upon how far you rotated or how many times to get things where it's supposed to be.
So the technical problem is you will screw up the poise of the balance wheel. The balance wheel is always poised with the roller in place rotating it changes the poise of the balance wheel. Although it probably depends upon how obsessed you are with positional errors the size of the roller table etc.
then this tool mentioned above Bergeon 3007 Swiss Tool for Collet Closing, is for tightening loose hairspring collets. for variety of known and unknown reasons hairspring collets can be loose with time. You go to rotate them and they just aren't tight enough to stay in place. So with this tool it's relatively safe to tighten the collet without bad things happening to the hairspring. At least most of the time sometimes you can still catch the hairspring where it shouldn't be and then you'll have to put it in the flat. usually the worst thing that happens to hairspring collet's is in restaffing is the size of the staff is somehow different than the original. Sometimes people try to force it on the collet can actually crack. then a course with all their watches they been re-staffed several times and things just happen.
then at least at one time they made tools for rotating hairspring collet's. Somewhere around here I have photographs conveniently I'm not finding them if I find them I will attached later. The difference between them in a screwdriver is the taper is much longer. Whatever you put into the crack of a collet isn't supposed to open the collet when you rotate. Just the twisting action alone will open the collet a very tiny bit you shouldn't have to wage something in do it. There's a danger with screwdrivers because of the taper of opening the collet up too much and ending up with a loose collet.
The roller table I was trying to rotate was on a cheap pin lever movement. However it would not budge even with pliers and as Frank says if forced it could actually move the balance staff. Therefore I think I will give this tool a miss. I am now looking at making a better collet mover by shaping the end of with a thick pin & controlling the pin with a pin vice.
On 10.2.2017 at 0:37 PM, rodabod said:
Does it not affect the poise of the balance complete if you rotate the roller?
Hi,
completely - not at all. A tiny tiny bit - yes.
Once I calculated, if the gap for the safety pin will compensate the weight of the jewel. Result was, it does just partly, about 1/3 if I remember well. But the effect is very little.
Frank
On 2/14/2017 at 5:30 PM, praezis said:
Hi,
Frank
I guess you would need to make positional rate measurements before and after to find out how much.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
