Generally any type of dial, first. And second, specifically this Longines. Some lettering is already gone so I don't want to damage it but at the same time it seems it could use some TLC. Or should I do nothing with it? 17157c9ad7b2891b6fee34f46aa36b95.jpg
Don’t do it yourself you will only make it worse. It needs to go to a professional watch dial restore. It will be expensive so ask for an estimate.  It is a very good watch.
Edited by oldhippy
As Hippy suggests, this can be dangerous territory.
There are many different techniques and materials used to create watch dials and they all react differently to different cleaning techniques.  In some cases you can safely wash in soapy water with a toothbrush and in others the lacquer will fall off taking the painted markings with it if you stare too hard at it... ask me how I know...
There are specialist dial restorers around who have learned the hard way and tend to keep their knowledge to themselves. I've never used one but those I have looked at will not generally give a quote without seeing the dial. Expect to pay at least £100 from what I've read elsewhere. See here for an example http://www.watchdialrestoration.co.uk/
S
£100 to restore a dial I wish , I sent one up to V Soni in London , so they could have a proper look at it and give me an estimate ,£280.
Needless to say I didn't get it done
Being the Devils advocate, I would suggest having a go. Take plenty of photos, do the research and if it all goes south send it to a dial restorer. If you're not happy with the dial you may get a good result & save yourself £100 or so.
Don't be so stupid. Each of those markers are individually fixed to the dial. No matter what you look up on the net it doesn't provide you with experience which you don't have. The more damage you do the more it will cost. Longines watches are not a run of the mill they one of the top brands and can be highly sort after.
Personally if as my dial I would find somebody that's specializes in this and send it to them. But isn't my dial and you're asking a question.
So first step of solving a problem is what is the problem? So typically a wristwatch dial is not dirty as it is sealed behind a crystal. So you're not looking at something that's dirty that can be washed you're looking at something that has aged with time. A lot of the white dials are frosted silver it's a silver finish it will tarnish with time especially as the lacquer disintegrates. The various lacquers they put on the paint everything can disintegrate with time. Washing is not going to help that at all. The printed letters that are falling off or whatever happen to them touching of those is going to make that much much worse.
Then fortunately there are still companies specializing in restoration of dials if you don't like the price of one shop around. Some of the pricing may have to do whether they have to make a special plate for printing the letters in other words they don't already have a plate for that dial.have to make a new one.
Some of the letters in "Longines" are missing, and for me, that's it shot. I'd search for a replacement one. They do turn up eventually. I don't really like re-painted dials.
Just my opinion but old watches should look old the dial on yours would be perfectly exceptable to me its original and shows its age but is still usable.
I have seen many truly horrendous redials that look just too sterile and obvious thus ruining the look of the watch, I would live with it. Just keep it in mind and you may find one pop up on Ebay at some point but at this stage I would not be looking to do anything with the dial if it was mine. Once its restored it's no longer original and it cant be undone later, for now live with it and save your money.
Defintley in my opinion
Edited by wls1971
If you look at the discussion groups with wristwatch collectors you'll notice that they don't believe in changing anything in the watch. Is not even clear whether they would be happy with replacing parts if they were broken I think the purists would be unhappy. So from a collecting point of view they would rather have a tarnished dial than a nice new shiny dial.
On 12/28/2016 at 0:00 AM, mcass said:
How can you clean a vintage dial without damaging it?
"cleaning" implies "dirtiness", but most often vintage dials have corrosion or other damage, so cannot be "cleaned".
unless you have a spare dial, don't.
90% of the time you make it worse and I'm speaking from experience of trying the so called different methods found on the forums (lemon juice, vinegar, dish soap, dish washer) and yes, I had roasted dials to test each method on.
none delivered what they promised.
either buy a new dial, get it refinished or soak up that patina which only comes with age.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
