When cheap Chinese tools fail
clockboy
I've had the same unit for about three years now and havn't had any problems. Having said that, before I started using it I put a spot of loctite on all the wing nut threads just for good measure.  To be honest it was so cheap, it names it one of the best valued pieces of equipment I have bought.
2 hours ago, rogart63 said:
Not really a winder? It's a tester? For testing automatic watches?
It is indeed for testing watches, but not just for automatics.
I use it when regulating all watches after a service, it cycles the watch through all positions and gives you a good idea how good the watch will keep time when on someone's wrist.  Even having set a watch this way, sometimes it has to be regulated to suit the wearer.
I bought this a few weeks ago and found it extremely useful to test the winding ability on autos, and also provide "real life" timekeeping data as mentioned above.
mine has needed threadlock on every nut, and I was already planning on filing a channel on each holder, it looks like I'd better do that sooner rather than later!
This is a Bergeon watch winding machine. The cost of this is almost $800.00.
Bergeon 5803 Automatic Test Automatic Watch Winder 110 Volt
This is a Chinese watch winding machine. The cost of this machine is $64.00
Automatic test for 6 watch winder Mechanical for professional Use high quality
Hmmmmmmmmmm!  Do you suppose that both machines are made in the same factory in China? What sales and marketing magic could possibly be at work here?
david
Some of Bergeon equipment even comes from China where it's assembled, so the chances are that unbranded are very similar, and maybe QC failures of Bergeon, cosmetically for example.  I have a Bergeon Demagnetiser, and a China version which came from China with the Bergeon branding still attached, go figure.  I returned the Bergeon for a refund.
I have suspected that for a while. I purchased a Bergeon watch hand lifter ( Bergeon 30669-4)
& the centre pusher would not centre so I sent it back. My Bergeon mainspring winder I am sure is not the same as the vintage one you see Mark use the arbours are way too fat & the entry hole is far to small.
The Bergeon cannon pinion lifter is good but not for small cannon,s.  I have since found that they are not the same design as the original such as Mark uses.
Bergeon rant over. I find however Horotec tools first rate.
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
