JDM,
In the watchmaker style lathes there are three basic designs. These are the JACOT, WW, and GENEVA style lathes. The reason they look similar is because I have more than three. I have other small lathes such as two UNIMATS but I do not consider them to be watchmaker lathes. The reason for having so many is:
1) I like the machines and enjoy restoring them.
2) An investment for my later years. The increase in value of these machines has far outpaced my 401K.
david
19 hours ago, StuartBaker104 said:
The sincere lathe can be found on ebay.com but not ebay uk, although it appears they will ship to the UK. Sadly, it looks like £500 for the lathe, £250 for a set of collets plus shipping and duty, which is going to take this over £1000...
Compare to the Vector for GPB 3,900 which is the same product, full options and boxed.
https://www.hswalsh.com/product/vector-watchmakers-lathe-hl11
Attached for reference the summary of prices and ebay Items from "sincereclocks"
This is not a cheap hobby. But still cheaper than others:D
LATHE PRICE (1).xls
AlecJ,
If I have the time I will post some more pictures of my shop. There are a lot more lathes and other machines that were not in the current pictures.
david
On 17/12/2016 at 1:53 AM, david said:
Tmuir,
I have only seen pictures of the BTM lathe and have not seen the actual lathe. I looks almost exactly like a Geneva style Boley but I don't know if the companies were connected in any way.
Mark Lovick has a video on Youtube showing the disassembly and assembly  of his Sincere lathe. I think the video was about changing the drive belt but also shows how to take the machine apart and put it back together.
david
Hi David,
Sorry for being slow in replying I've had a busy few days.
The BTM was made in England for the British military and their allies during WWII and is basically a direct copy of the Bolley lathe as for some reason German made lathes were in short supply in the UK during this time. :D
I have never had access to a Boley lathe to compare it directly to my BTM to see if the parts are truly interchangeable though, but I am guessing they would be as it would of allowed what Boley accessories were in the UK to be used with the lathe.
The lathes have two finishes, 'War Finish' with is black crinkle paint on the stand and grey paint on the rest, or those that were made after the war have a chrome finish which were made to sell to the general public. Obviously after the war many became war surplus so 'War Finish' ones are more common.
Is the video one of Mark's premium videos as I haven't come across it on his youtube channel and have yet to subscribe to his premium videos although I can see at some point next year it will become worth my while.
Tony
Tony,
If you take it apart clean  all of the bearing components (spindle, cone bearings, thrust bearings) and make sure there is no grit or other contamination on the surfaces. I like to use hydraulic oil as a cleaning solvent. When I reassemble the spindle components I wack the collet end with a piece of soft wood to help seat it. I then tighten the nut in the back until the spindle begins to bind. After that I back it out by about 1/4 to 1/2 of a turn and the spindle should turn freely. You can then run it for a few minutes and check for any heat build up. When it runs without end shake and there is no heat build up you have it adjusted properly.
david
Thanks David.
I've yet to get it out to check as Christmas preparation got in the way. When asked by the wife to stop what you are doing and help sort out everything for Christmas I know better than to argue with her.........
Santa was good to me today... my Boley & Leinen lathe arrived as expected. I will have to strip it down and clean before trying it out as it's very grubby.
At the risk of starting an international incident, can I please ask for suggestions on spindle oils that I can buy in the UK? I have seen that I can buy Castro Hyspin 32 in 5l cans from RS components for about £20. Seems like a lot more than I need, but I can't find anything else obviously suitable in smaller sizes.
Also how about suggestions for oiling the cross slide?
I've seen that I should use petrol to clean it with... but disposing of a large quantity of dirty petrol won't be easy, so planning on white spirit :-)
Thanks
S
I'm not sure of the correct oil to use but if you go to Myford lathes they have several different grades purely for general oiling and one for headstock bearings. Sold in 1 ltr cans.
Myfords are small lathes but well renowned for their quality so I would think if the lubricants are ok for their machines they would be ok for any small lathe
I have found that hydraulic oil has a good viscosity for the cone spindle bearings. I do not like extremely thin oils such as 3&1 oil. I personally like to have lubricant on any two rubbing metal surfaces. As long as the surfaces are wiped clean and re-oiled on a regular basis to prevent the build up of gunk, you should be in good shape.
david
Thought it was time to share some pictures of my new lathe now it's all cleaned up. Sorry, no pictures of it in pieces, but my hands weren't in a fit state to touch my phone or camera.
It was extremely grubby and the rear bearing was very tight on the spindle and took some removing and a bit of polishing to make it fit properly, but apart from that all was very straight forward and it seems to run very true and smoothly when adjusted. The cross slide has lost most of its plating, but the slide rails are adjustable to take out any wear.
I patiently rewired the 50 to 60 year old motor controller (sewing machine type), only for a big capacitor in it to go bang after 5 minutes, so I decided a new motor and controller would be a better bet. That's still in the post, and I'll wait for it before mounting on a board.
I would like at some point to find a tailstock drilling attachment - one popped up on ebay today, but it's expensive as it has a whole tailstock with it that I don't need and may not be able to shift on again. I also need to get the female end of the tailstock runner re cut as it's quite badly chipped.
I followed the instructions inside the lid and have boight some Mobil velocite #6 for the bearings. The cross slide has a thin smear of grease for now, so will see how that goes.
Edited by StuartBaker104
On 2017-01-04 at 5:15 AM, david said:
Stuart,
Your lathe looks like a real treasure. I hope it inspires other forum members to post pictures of their machines here.
david
Ok, here are some pictures of the lathes i use at the moment!
The lathe I use the most, Boley/Leinen Reform
A sturdy Boley used mainly for lapping details on watch cases
For bigger objects I use my Boley Prec.2
Currently under resoration, a Wolf / Jahn 8mm lathe with a whooping 493mm bed - intended to treplace my Boley for lapping jobs etc.
And finally a Harrison M250 - used for making parts, jiggs etc. for the lathes etc.
Edited by RCDesign
So I went to the watch and clock fair at the NEC last weekend. It seems to get smaller every time but it's only 10 miles down the road for me so it seems churlish not to pop along.
I did have an objective, which was to talk to the people from PennyFarthing tools about tailstock drilling attachments for my lathe. Their answer wildly exceeded my expectations and for £35 I bought this which is a ground bar fitting my tailstock with a taper fit precision 3 jaw chuck.  They make them in house and at it's first outing I used it to bush a watch barrel.  May be a bit of a stretch for pivoting but very happy so far.
  • 7 months later...
On 12/14/2016 at 10:20 PM, david said:
I have been collecting and restoring these machines since 1970.
david
And I need to buy one:)
Edited by jdm
Please don't include pictures in quoting
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
