Have a love affair with Seiko and after some years of wearing a one and only Seiko 5 with a 7S26 B, decided to lash out and buy a new Seiko Sarb035 as a dress watch. This has led me into delving deeper into the world of horology and am starting to put together a small tool kit with the object of opening up a 7S26 movement to get the basics of a mech. movement. Currently looking around for a cheap new Seiko with the 7S26 movement to work on. Not prepared to open my Seiko 5 till I know what I'm doing.
First question - how do I confirm what movement a Seiko sold as a SNKM61 has or is this another movement type? Is there a reference table for movement types? Many sales specs only list their watches as automatic or mechanical and I'm not prepared to buy until sure it has the reqiured 7S26 movement. Been searching for a table but no success so far, any help would be appreciated. Certainly shows me as a beginner - but this site looks like a great place to get going.
Cheers.
Sorry don't have a table like you want, but have you tried looking on ebay with a search calibre 7S26?
There is one on ebay US that looks reasonably priced, but it finishing in just over 20 minutes so you better be quick.
I forgot to add welcome
Edited by Tmuir
Added welcome message
Welcome to the forum, clicoon!
No, no table I'm aware of. There is always the model number and usually those are poorly connected with the movement number inside....at least I've always spend too much time to find the relationship for certain advertised models.
For practicing and before you work on your own watches, you need something working and with no real value to you...."guinea" watch? There is a tutorial from Hacko, on line that can get you started. We also have an excellent walk through by Lawson and Mark has a super video of the whole process. So you'll be good with those.
I usually get movements and whole watches from "thewatchcollector" on ebay. That's one source that you can expand by searching by caliber: 7S26. I'd recommend version C but that one may be hard to find. I you want a new movement, CusinsUK sells the 7S36 which is the same (it adds 2 jewels and a small bridge as a debatable refinement).
Cheers,
Bob
Thanks folk for the warm welcome. Bob - I am aware of the tutorials available and should have mentioned that this is the main reason why I decided to launch into some practical work. Could not have considered doing this without the great videos from the sources you mention.
A big thanks to ro63rto for the Seiko links, have already clarified some issues by using watchsleuth.
Now to get busy while ensuring 'the lady of the house' doesn't feel deprived of a useful house hubby!
Cheers.
Welcome Clicoon. Hope you enjoy the forum. The Seiko 7s26 was produced by the millions so there are plenty of them to be found. It is a very simple movement to work with, however parts are becoming harder to find so purchase a running movement if possible. One of the difficult parts to source (as I have found recently) for this caliber is a replacement mainspring.
Hi CB,
You are right! Other than a generic replacement, I've found that this number SEI201420 from cousinsUK may be better since it is the whole thing: barrel and mainspring. You may save money too. You can give it a try...Please, double check the number since I also work on the smaller caliper 4205...
Cheers,
Bob
Thanks Bob, I found one complete with barrel on the Bay. Also as a back up I have also ordered a spring GR2378X which is apparently very close to the original.
Hello Clicoon and welcome,
Looks like you are straight into the fray and keen as mustard.
Look forward to seeing how you get on.
Cheers,
Vic
Hi All - a quick update. Finally managed to get a used Seiko 5 with a 7S26A and after checking the website provided by ro63rto got full specs for it (SNKA23). The watch cost $48 Aus. ex ebay, it was described as a goer which was true but it only goes intermittently. While it looked clean at first sight, since opening it is clearly not that clean inside and probably needs a strip down service.
I've got down to the day dial and starting to wrestle with the snap or circlip. I'll soon need to think about cleaning fluid and oiling but a bit deeper to go yet.
Cheers.
Excelent progress Clicoon,
Mark has just put on a vid about oiling that brings it down to the basics a starter needs - may be worth a view.
A query about cleaning will bring a host of differing opinions but my two penneth, for a tinkerer, is clean in Solvent Naphtha (Petroleum) Light Aliph, lighter fluid as pure in Naptha as possible (and wash in isopropanol and leave to dry.  I dont do enough to warrant a watch repairers cleaning set up with a proper machine and litres of fluids.  I use a fairly standard medium sized "true" ultrasonic cleaner (ie not one that merely vibrates at a low frequency) and put water in the bath and use miniature jam pots to contain the parts within the fluids, the vibrations pass right through the pots and clean the parts. PS don't put the pallet fork in as you may detach the jewels - do that by hand. - it works for me!
Doubtless there may be a few differing opinions but all are worth a listen before you decide.
Good luck on your quest.
Vic
Thanks Patron - will look at some vids and absorb. A lot more to cleaning than I expected. Had thought about working on a newer watch to start with, thus overcoming the need for cleaning and lube, however, the idea of pulling apart a unit that didn't need service, with the risk of making it worse than when I started, made me go for a genuine repair/maintenance option.
Cheers Rob.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
