Stupid day
Tried to correct shape on an hairsping, It wasn't even much wrong. Failed miserably with the typical (for me) sequence of any corrections making it worse. Now is junk.
Grabbed a brand new balance complete, End stud has to be inserted on the balance cock (ETACHRHON, not screw type). Did not follow Seiko instructions to do that with the balance mounted, slip push and pull, another one is distorted and goes  to the trash bin.
Tapatalk on my "new" smartphone doesn't connect.
Stupid day.
I think we all have those days jdm don't get too upset. I was servicing my father's watch a couple of weeks ago. It took me a good nine hours and when I was done the clutch wheel didn't want to engage to wind the watch! I ended up taking it all apart again and in the process lost a small spring that flew across the room and I just gave up. It really got to me and lowered my confidence, but I realized that everyone makes mistakes how else can we learn?
It took a lot of time and concentration to drill both end of the balance of the Agat stop watch. And ruined all with a replacement pivot having to big cone angle.... I make this mistake a second time :pulling-hair-out:
Put this project aside for a while.
Edited by szbalogh
I did a strip down of a really nice Seiko 2206a movement last night.  Everything went swimmingly.  I put the balance cock on a balance tack for safe keeping before reinstalling it after strip down.  One errant movement sent the balance cock off the tack and across the desk.  Literally, it flew like a click spring from my tweezers.  (sigh)  That's when you know it's time to pack it in (and maybe have a drink).  Luckily it appears the cock, balance, and hairspring survived.  It'll be amazing if that's the case.  We'll see.
We all have days like this I'm sure.  I have two containers with cursed movements in them.  Nothing I do can go right with those two.  I've turned a hairspring into a tiny little rat's nest too.  It's amazing what skilled hands can do with so little effort!
I hope things go better for you later.  Usually bad days are followed shortly by those amazing days where everything goes right and you think, "this isn't that hard".  ^_^
Thanks guys. My issue with myself is that I've already made small pile of destroyed HS. Even if Seiko parts are not expensive, it's such a waste. Admittedly today wasn't my better manual ability day and I should have gave up since the beginning.
There are reasons why I work on mostly pocket watches, the larger the better. The parts are much bigger and a bit easier to work with. The added plus is, I really like pocket watches. However I frequently loose or break things, It gives me an opportunity to use as much bad language as I can.
Im OCD with my watches and I have screwed up quite a few when I really shouldn't have touched them. Don't get too down about it. At the end of the day they are just objects anyway. And they can be repaired.
Absolutely, no big deal. But I need my watches to work well in order to sell them. This one had a poor amplitude to begin with, so money/time investment was in the budget already.
Last couple of days I have been trying to learn to use a mainspring winder.  First two attempts ended up coming out into nice tight tangled balls!
On a positive note......I think they may make nice Christmas tree decorations!
Eric
I've had similar repair slowness due to parts retrieval, this Seiko 8306 has more springs that 1950's mattress! I have pinged a few around but luckily found and got back in...Installed a new day wheel and it still won't advance, so off with the top end again, checked all setting and winding functions, still good, but man what a time with this one... thought I had date jumper spring in backwards.:huh: Then the ^%$# crown came off! :pulling-hair-out:
 My luck, it's my watch and not a friends. My empathies gentleman....DSCF0321.JPG
I've done that! Mine did not survive intact. Out of flat now. I think I can fix it, but am waiting for a nice relaxed day :)
Well unfortunately the same happened to me- hairspring looks like a whirling dervish.  Thankfully Seiko parts are not expensive!
    • The final result is not perfect looking, but is working well. The wheel is pritty small - the OD is 1.8mm
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
