Transparent Acrylic Manipulation Rods eBey
SSTEEL
Just an heads up really.
HS Walsh has these on eBay, Bergeon branded, and in true form of this brand, expensive, just for one, €11.28 plus shipping...
          Bergeon 5206-40 Transparent Plastic C...
I get mine from here, 6 pieces exactly the same, less than €2. delivered.
6PCS Dia 5mm Clear Round Perspex Acrylic Rod PMMA Circular Bar 25cm Length
15778776844_f00c8495f5_k.jpgUntitled by Micky Aldridge, on Flickr
Edited by SSTEEL
1 hour ago, clockboy said:
Not surprised it is always wise too research before committing to a purchase.
However what are they used for ?
Manipulation of parts CB.  Hold down a bridge with it etc whilst aligning, screwing down etc.  I also use a fine ended one for moving hands into position whilst refitting hands.  I also have one which is refinished like a flat screwdriver tip. this comes in handy too for various tasks.
Agree, I also use peg wood for certain applications.  I also use finger cots.  The clear plastic manipulation tools are really only for presentation, I photo document most of my work, with videos also, and this tool is mostly used as a pointer to highlight an area of a movement which is problematic.
Edited by SSTEEL
While travelling with Swiss I have watched a video in which Breitling only uses acrylic:
see 7:23 and other sequences.
My understanding is that for production, acrylic is better choice because it does not leave any residue, so is more apt for fast, repetitive work.
Unlike acrylic, pegwood is a fibrous material, observe under magnification how indeed there are chances of minuscule particles being left on the movement, but being more flexible, is better suited for uses where the pressure can vary, or the tip shape must be frequently changed, etc.
So it think in the end the two stick have two different application, but for general watchmaking, pegwood is better.
BTW I found that my BBQ skewers work even better :)
That is smart . I bought some big orange wood sticks that i frequently use for holding down parts with my left hand. But has been thinking of testing some plastic toothpicks to avoid getting those small parts from the wood. But would buy a acrylic bar and test how that works. would be great if they had some color though. So i could see them on the table :)
    • Hi other than testing the coil without the proper tools it will be difficult.  If you +an rig up an external supply and attach it to the cut block you may be able to pick up the pulses on the chip if not on the coil. i have attached the parts sheet for the watch 9362 which gives you the part number of the cut board assembly, whether this part is still available or not , who knows. ETA 9360, 9361, 9362.pdf
    • Hi and welcome. First of all, check the power reserve. If the watch is runing, this means the spring is attached to the barrel arbor. If there is no end of winding, this probably means that the spring is not attached to the barreland it's outer end is slipping. In such case, the watch will run, but the power reserve will be small - about several hours
    • Hi welcome to the forum. One can only reiterate the diagnosis already made by clockboy mainspring problem. But before tearing it to pieces take a little time to read the attached file to acquaint yourself with all the various parts. TZIllustratedGlossary.pdf
    • We think about these preps as "one-dips" partly because they are terrific solvents but also because the parts they are used on are often cleaner in general than many other parts. But old oils petrify, and even something like B-Dip can't clean up over-soiled parts without some extra effort, as mentioned above. There is an intermediate step during cleaning where the solvent can partially dissolve tarry residues so they have a more liquid varnish-like consistency, and that could well be what you are seeing on the coils after two washes. I wouldn't worry that your B-Dip was contaminated before you used it on this hairspring, but it I wouldn't re-use that aliquot AFTER this cleaning!
    • Welcome to the forum, enjoy.. Normally if a hand wound watch does not fully wind ie just keeps winding there is an error with mainspring, either slipping around its winding arbour or the mainspring is broken.
