I thought I would work on something a bit bigger than a watch for a change.  My sixteen year old Triumph Daytona is now as fresh as the day she came off the production line and ready to go?
  • Like 9
Class work GEO [emoji3]
My attempts are a pale imitation of your standards of workmanship in both watch and bike restorations.
NAD
Excellent bike! I would like to try it! :)
I have a Legend TT 900. All bearded scary gang guys on the Harley meeting here in Hungary were looking at my bike and were asking what the heck is this Wow! bike? :) I liked that so much. Triumphs are really rare here.
You wouldn't be disappointed Szbaloh.  With only 130 BHP it's fast but not super fast.  The balance of power, brakes and handling make it just about perfect for use in the real world.   Back in 2003 I did a continental trip with it and it was superb. I even took it up a dirt track to the top of a mountain when I was there, but it's certainly no trials bike!
Yes,mine has only 72 BHP but a lot of torque. I think that the engine could handle bigger transmission to get to higher speeds :) this bike is not for that however.
I think it's called pride in workmanship, it is better than most of the bikes I saw in the SanDiego Automotive Museum in Balboa Park. I must send you those pics.
Then again I am not really surprised.
lovely job George.
Vic
I suppose it is in topic and I doubt that George would mind so here they are.  The last one is the Apollo 9 Command Module, not a bike but it must have been a hell of a ride.  I am not a motorbike person myself, preferring to be clad in steel when at speed (wimp), but I enjoyed looking at them.  This is a glimpse of some stuff from the British section.image.jpeg
Cheers,
Vic
Oh ho! I love Nortons!!! Thank you for posting, Vic.
That last picture, I think the module needs some TLC!
Geo, I wonder if you would take it in and do some magic on it...that red you used in your bike would be perfect, I love that color and the hue you chose! Not all red paints are made the same! :)
Cheers,
Bob
PS. Yes, me too Vic, I enjoy bikes a lot but like to brave the Miami streets armored just like you...If tanks were street legal I would be driving one! :)
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hairdrier) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
    • I had one success (and one failure) dissolving a broken stem out of a crown with Alum. The successes was a stainless steel crown and a milder steel stem. A Tag Heuer 2000 Automatic - here with the solution at around 60ºC I could see small bubbles coming up from the stump of the stem and it took maybe 6 hours to disolve I tried to repeat this with another watch and it did nothing.....  This was A Bulova Ambassador with what again looked like a stainless steel crown.
    • That good to know in one way.
