I have a square Bulova Accutron that has a pretty badly scratched Glass crystal. Its 29mm across the flats and has rounded corners. The 100 Year Accutron Anniversary issued in 1975 is slightly similar, but has a 30mm square one, which appears to have very slightly bowed sides and are available at around £30.
Mine however Isnt one of those, I cant find out much at all about it at all.--its a couple of years earlier and seems to be a very rare one, and a chunkier heavier watch altogether. Only found a couple of references to it on the web. Seeing I boobed and it no longer has its name on the glass, a new crystal could possibly be marked/painted with the name etc...
Here it is, The Case Number is 7387 and dates from 1973-- It wouldn't be out of place in that old Si Fi series, Space 1999!
Edited by Alastair
I think I have seen them in the cousins catalogue supplied by size.
My question would be how do you fit a square crystal.
there is a guy who sells  accutron crystals in the US  (one of the guys who bought parts when the accutron  repair shops closed down) .  i have a round space view and refused to pay $ 200 for an original crystol.  good luck with  square glass !  i suggest " professional polishing.   vinn
Hi Alistair,
This is a pretty specialized challenge, and you may need specialized help!  I would try some of the following...
Ask at mybulova.com - a member on there sold me an original glass crystal for a 1920s ladies watch!
Contact electric-watches.co.uk - this is clearly their thing
There is a uk seller on ebay called grassbox2020 who seems to specialise in accutron repairs
Regards,
Stuart
Thanks for the links rogart,
WOW! 100 bucks for a crystal!!--Unprinted too! (Of the wrong size, 7581 comparatively common anniversary model as opposed to the unknown and squarer 7387--No one on earth, except this guy on Bulova Accutron forum has correct one--Who wont sell it, even after making a whole thread with lots of pictures of it as if he was selling, Strange!)
Ive found a fairly local Co that can make one also unprinted for less than 20 bucks, and can probably even make it out of Sapphire too if needed,--I'll check with 'em when I take the case to them, I may as well get a few made, and experiment/find a printer for the logos etc....
Here-- http://www.watchglasscutting.co.uk/web/
Only problem now--How to sort out the Printing on the inside of the glass....
Edited by Alastair
There are aftermarket seiko crystals from the Philippines that are like that. If they can somebody else can also.
Ha! Philippines seems an awful long way to go--Especially when I can get the crystal made just up the road--In Abergavenny!!
Sure there's someone here in Welsh Wales can do the printing job...
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
