Tips
Evening gents
Just wondered if anyone has advice on how not to lose shock springs etc, I managed to lose a shock spring last night but luckily found a substitute which was not an exact match but does the job very nicely.
Please tell me I am not the only one, dare I ask does it happen to pro's as well?
Good tweezers are the first tips. Rodico to hold it could also work? Depends on what kind of spring it is? A jeweler picker is a very good tool? Check it out on Cousinsuk or Google it. With silicone tip. Used for picking up the spring and put it in the box or back on the movement. download (20).jpg
Edited by rogart63
For me, dropping springs is usually a sign I'm getting tired. I may drop a part once but if it happens again I know the chances of something flying is high. Usually when I persist in spite of the warning signs, I end up on my knees with the small broom and dustpan.
Anil
I have found when releasing the spring it,s best to steady with a piece of pegwood so it releases gently without flying away. For the trior style springs I made a removing tool out of peg wood. A hole in the middle & three cut outs so all I have to do is twist & they release without any chance of flying. Or you can purchase these tools but I found my peg wood version works fine.
Just prepare yourself in spending many hours sweeping the floor on your knees so make sure you have a nice brush handy. :D On more serious note good tweezers are a must and try to get in the habit of demagnetizing your work before you start taking it apart this can save a lot of hassle.
Ah the old springy boingy things that are attached to watches. I usually work inside a large clear ziplock bag movement, tweezers, driver, pegwood and right hand inside zipped up and rest of me outside then if anything flies I can usually find it I think the longest I've searched for a spring is 2+ hours before giving up and consoling myself with a large vodka.:D
    • “Traditional” was probably a poor choice of words. What I was trying to say was that I perceived Waggy's proposal as more modern than the now generally accepted one. Water and sugar? Do you have a source on that or is it just a guess? Is the inside of the crown stainless? Water and metal don't sound like a very good combination otherwise.
    • Hello and welcome to the bottomless rabbit hole! 😉
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
