Junghans J 87 Movement November 1961
Hi I recently purchased an old Junghans Movement with dial and hands. I did some internet research and it turned out that this movement is older than me!
K1 is stamped to the plate.
K = 11th character = November, 1 stands for 1961
The first thing I did was demagnetizing the watch. The watch was fully wound after I got it and did not run. But that was an easy one:
The hands are bent and block each other. After removing the hands, the movement started running immediately.
Then I checked the movement with my brand new Weishi 1900 Timegrapher. Not that my old No. 1000 didn't work. But I love the higher resolution. Not really necessary.
The upper picture is taken face down and below that face up.
I have two questions:
1) How do I straighten the hands without ruining them?
2) What does the irregularity in the blue line of the second graph tell me?
Thank you for your support! I will now start disassemble.
Cheers Alexander
Edited by AlexanderB
typo
Measure it with the other timegrapher as well or try adjusting amplification and gain! Maybe low S/N for that tick.
The lower line error showing some regularity. Maybe one escape wheel teeth is not like the others. Check also the lever pallets.
Here we go with the disassembly:
Removal of Hour Wheel and Canon Pinion. Not too much to see but I love these close-ups :)
Balance Wheel looks good as far as I'm concerned:
After removal of the balance I removed the pallet bridge and pallet fork. Still assembled in the pics.
Closeup of the picture above.
Pallet Fork looks good to me.
BTW all parts are not cleaned yet.
Next was the crown wheel and the barrel wheel. I almost killed the ratchet wheel screw!
My notion was that the crown wheel was attached with two regular screws to prevent having a left threaded screw. After I removed the crown wheel, I started to unscrew the ratchet wheel, but to no avail! I pressed harder and it did not move. Then Adrenalin pumped through my veins! It has to be a left threaded screw, occurred to me. So I tried "fasten" the screw and ... it started moving.
OK. Another experience.
BTW, this time I adjusted the screwdriver blade with a grinding stone to fit perfect. What a difference! The blade sits sound and safe in the screw head. No slipping away! Just perfect.
Some more pictures...
Click and Click spring.
Barrel Bridge removed.
Train wheel bridge removed.
Yer another bridge for the intermediate wheel, right?
Here you can see that someone earlier tried to pry the bridge off with a screwdriver I guess. Indeed, the bridge was difficult to remove.
Here we go, almost done!
After removing all parts from the bridge side, I turned the movement and removed the setting wheels first.#
Next the keyless work:
And finally the setting lever, stem and clutch wheel and winding pinion.
Finally I removed the Incabloc of the plate. Different system here: I turned the spring carefully with my tweezers, until one of the three legs faced the opening. removed the spring very carefully with the tweezers, not grabbing it but gently pushing it. I wonder if I can get it back in place!
To straighten hands use soft objects, e.g. the stick from a q-tip on the mat.
The minor irregularities tell you that you have to service the movement, put it back together, regulate and check it before even thinking about that.
Edited by jdm
Thank you jdm. After I had worked on the ETA 2551 and ETA 2369, this one looks huuuuge to me! What I love about this Junghans movement is, that all the bridge screws are identical. What a relief! Tomorrow I will clean the parts and assemble it again.
I wonder if I will work on the beat error because this one has a fixed hairspring stud. I assume I need to loosen the screw, push or pull the hairspring a bit and fasten the screw again. I wonder if I am able to do this. Let's see.
I think the screw only holds the stud in place. BE adjustment may need to be done rotating the HS on the balance staff. But i wouldn't go crazy about that, rather I'd start looking for a suitable case. It will need a well domed crystal for sure. Let us know how you go.
Yeah, that's surely safer. I find interesting that in this balance the final arc of the HS is shaped without a dogleg. In the recent past member 275R was great at finding references to explain this kind of stuff, but we aren't hearing from him since a while.
Answer: I would gently re-shape by hand
Answer: one side of the escape action is not correct now & again. Normally after a clean & lubrications this goes.
Well done in doing that I can't stress how important that is it can save a lot of time and problems and it can even look after your tools. This is good and clear for all to see on how to go about taking this cal movement apart, fine photos and detail to. Well done.
Thank you for your kind comment. Actually, the importance of demagnetizing the movement first is something I took from this forum, maybe even from one of your posts, @oldhippy
From what I also get from your words is, that it makes sense that I take the time to post these walk through's.
21 minutes ago, szbalogh said:
Signal to noise ratio :)
OK, thanks. With this timegrapher I can set the gain. But I assume that it is not a problem of the microphone but with the escapement. Let's see how the movement behaves after cleaning and reassembly.
As Clockboy said, it will surely removed by cleaning.
Hey AlexanderB
Excellent write up mate, and the pictures are wonderfully clear.
I'm very interested in seeing more on the system holding the end-stones of the Balance ... they look very "old school" indeed.
Keep up the great work and writes mate!! :)
This time I want to present a couple of pictures on my cleaning. Since I don't have a watch cleaning machine I use a semi professional ultrasonic cleaner.
It has a heater and I usually set 50°C. I use an Elma 1:9 cleaning solution and set 3 minutes. That turned out to be sufficient.
I clean all parts in the ultrasonic besides
  • Balance / Hairspring / cock assembly. I just dip it entirely for a couple of seconds in Bergeon 2552 One Dip Solution
  • Incabloc stones.
  • Barrel wheel with main spring.
Everything else I put in little baskets (I have a couple of them), put the baskets in the basket of the US cleaner and let it run.
After the US cleaning is done, I wash it in clear water from the tap.
Next step: I take the parts from the baskets and dip them in benzine (I wonder if this is the right word).
I use a blower to remove excess benzine, like you can see in the picture below (before blowing).
I know: I learned not to grab the wheels like this to prevent scratches! It was just for the photo, I promise :)
As someone mentioned earlier in another thread, removing the parts from the baskets has be done most careful and thorough. I cleaned a movement earlier in my "career", and was not able to assemble it within a week or so. I wanted to fix the click and ... the screw was gone! I eventually found it in one of the baskets, stuck to the rim and ... totally rusted. Totally destroyed.
So watch out for springs, screws etc. in the baskets. You better look twice.
The screws were not placed there. This is an actual situation. BTW, someone recommended not to clean the screws. Especially for the old movements I am working on right now I consider this mandatory.
After taking the parts from the benzine, I place them on a special drying paper.
This is my setup for cleaning:
Important: This is how I do it. This must not necessarily be the way how "it is done". I'd like to hear your tips and criticism on that (can take it :) ). No hints, criticism or confirmation, whatever comes to your mind - no more pictures. :D
Looking forward to your opinions on that.
Cheers Alexander
The first assembly step is mounting the Incabloc to the plate. I cleaned the pieces in benzine, put a drop of 9010 to the cap stone, as I did earlier (see my 2551 thread) and dropped the two parts in the plate.
@Lawson asked about the mounting of the endstone so I took a couple of pictures to make it clear. There is a slot in the walls of the hole (I wouldn't even know how to describe that in German!). But I think the picture shows it quite well. You can also see the notch at 11 o'clock on the pic. This is where you can lower the three legged spring, one by one leg.
  1. First: put the Incabloc in the hole.
  2. Slide in one leg of the spring in the slot and make sure, another leg points to the groove.
  3. Use your tweezers to carefully push the second leg in the slot. You have to be extremely careful and work really slow. Push alternating the two legs by fractions of a millimeter...
  4. ...until the third leg points to the grove. Once more push the third leg carefully under the slot. Now you have to carefully push all three legs one by one until each leg is safe and secure away from the opening.
This is how it's supposed to look like:
It was easier than expected.
I am still interested in comments on my cleaning procedure!
Hi Alexander!
Excellent pictures and man, you are a pro both in the photography angle and the way you are doing this watch! Very good job indeed. You ask: "What does the irregularity in the blue line of the second graph tell me?" to me, the fact that the bridge is a little bent on that side appears to have disturbed the end shake/adjustment of the movement/wheel. This might reflect on the "noise" generated for the timegrapher to read. It appears not to be very serious -- although not good enough since it might be impacting the accuracy, error bit and probably amplitude. As clockboy said, check the scape wheel but in my mind it is a reflection of the above problem on the said wheel (not that there is anything wrong with the wheel itself...I don't know if I'm explaining it right). Of course, this is my take on it and again, I would definitely check how the wheels mesh during movement (remember the bent bridge). Double check after a good cleaning and lube.
Regretfully, I don't have a solution for a bent bridge and in the end you will have to maybe shim it or live with it as is, short of whack it to make it "flat" again (not recommended although doable). As for the hands, I usually straighten them with either my fingers or the back of the tweezers but it depends on how far gone they are. In the end I clean them with rodico (since I touched them). I've found that -- for some hands anyway -- the thickness of my bergeon mat give a fair height to "support" the tube of the hands so I can have half the hand on the mat to straighten and then turn it 180 degrees to straighten the other half while keeping the tube against the edge of the mat and supported by the actual bench at the bottom, flat (always working against the mat using the back of the tweezers or similar depending). Even the flat round "pusher" of the hand setting tool might be of use in some cases where you want to focus on a distorted spot. You will need another tweezers or something to hold the hand steady and in place for this operation. Never do a "rubbing" movement with the tweezers since they will scratch the finish of the hands....but you can do so with your fingers. All this "explanation" doesn't really apply when you work with the hands tube "up" and needless to say, lume is very frail and care must be taken not to damage it.
Maybe I'm breaking the rules in the watchmaking world but so far it has worked for me. Always try to protect the hand's tube and most important their point where they rivet together. When those bend they are almost impossible to fix with normal, everyday tools. IMHO.
Cheers,
Bob
  • Similar Content
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
