Ridiculous Packaging
A certain well known on line sales company that shares its name with a place that has a well known rain forest are always getting mentioned for their packaging, mostly mine has been ok but then - I was puzzled when I saw the delivery man carrying a large box as I had not ordered anything that big. I ordered a couple of batteries from Amazon, packaged they are each approx 9 cm x 12.5 cm x 5 cm and they arrived today in a box 59 cm x 46 cm x 16 cm !
Amazing waste of resources in so many ways but they were delivered quickly.  I will of course recycle it.
Cheers,
Vic
As you said Vich, the key word is: Rain Forest. This is a special packaging in case the carrier -- who picks your item up from the warehouse 2 blocks from your house -- has to make a detour -- it is only a few thousand miles -- through the ubiquitous Rain Forest to deliver it, safely.
Quote: "It is because of the perennial rain occurring in that place -- therefore the name -- your valuable order may get...well "rained". The vacuum created between the actual merchandise and the exterior of the box will repel all of the insidious rain. The extra filling: read packaging material, mainly paper, will wick away all of the detestable moisture that usually accompanies the err, rain(?) ensuring your valuable order to be preserved in a pristine, un-wetted condition. Our research lab in the North Pole has found out that this is accurate. We are working hard with the postal service on a new mailbox design directed to enlarge the official mailbox specifications, and lobbying with the proper government authorities, to make its adoption mandatory. This huge and modified mailbox will be mandatory and used by the different communities/individuals around the world to ensure that our packages can fit. This action will guarantee us to meet our goal: total customer satisfaction. Sincerely,
P.O. THE Amazon In Chief :smiley-face-laughing:"
How about that for an explanation!!!
Cheers,
Bob
The reason why they use expansive packaging (yep..."expansive", not "expensive") with rechargeable batteries is because if they explode there is less compression around them to create a bigger blast.  A mostly empty box will absorb some of the hit from a blast, you see.  That's what I was told when I queried the delivery guy as to why my pack of AA Eneloops was packaged in a 30 x 30cm box from the "rainforest".
So, stroppy I believe you just hit the nail on the head! Based on Jeff's items experience I will assume, as a general rule, "the smaller the product the bigger the bang therefore the box is chosen proportionally...bigger!" :)
PS. Just having fun here!
i can identify with this. i work for a company that delivers it's own items. the guys that package the items use absolutely no discretion when it comes to packing a box. i've delivered boxes that i can hardly lift, while on the same order, there will be a box packed exactly like the OP's box above. ridiculous.
Just as an addendum,
When I folded all the packing paper inside the box up to go in the recycling, I weighed  it.   The weight was 1.5 times the weight of one of the batteries and if the large box was then included then the packaging weighed far more than the product.
The batteries were both packes in their small tough thick cardboard boxes and inside the small box the battery was protected in the usual shock proof blown plastic insert - immovable and safe as you could want.
Cheers,
Vic
image.jpegHere's my experience of ridiculous packaging this week.  It was left by Hermes last week in this state, open at the end and no content.  I don't lay all the blame with the carrier, if the company I purchased the goods from had even run a bit of tape length wise it would never have burst.
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
