Picked this up recently for a snip from an excellent fleabayer in Japan:
A fairly clean item from August 1968 with a good dial. Being a bit of a fan of Sportsmatics, I haven't come across this particular model before & wrongly thought at first that it had a cyclops crystal retro fitted. Further research showed this to be the original configuration, however the crystal was in fairly poor nick & appeared to have been polished a few times in the past. After some more detective work the part number was obtained & amazingly Cousins had one in stock:
So far so good, although the rotor sounds a little rough (not uncommon on these). Lets see whats inside:
Bit grubby with a scraping rotor, but the bearings seem OK, so the rotor gets bent upwards slightly - don't frown, it's what Seiko recommends!
Out of the case, dial & hands off, strip down the dial side. Note the broken setting lever spring, I have a donor movement from a previous project and will replace this:
post-80-0-88468600-1457205582_thumb.jpgpost-80-0-61565600-1457205587_thumb.jpgpost-80-0-06895900-1457205592_thumb.jpgpost-80-0-45987400-1457205596_thumb.jpg
Turn over & rotor off:
Remove the winding gear:
Strip down the above, a bit of wear on the magic lever but appears to work fine, clean lube & reassemble:
Onto the main stripdown:
post-80-0-85418800-1457206066_thumb.jpgpost-80-0-20739100-1457206071_thumb.jpgpost-80-0-53386600-1457206075_thumb.jpgpost-80-0-93160000-1457206079_thumb.jpgpost-80-0-37013400-1457206084_thumb.jpg
All in bits & cleaned:
Lower Diashock dismantled, cleaned then reassembled:
Then it all goes back together:
post-80-0-65098900-1457206113_thumb.jpgpost-80-0-17995900-1457206118_thumb.jpgpost-80-0-05419300-1457206122_thumb.jpgpost-80-0-63800500-1457206129_thumb.jpgpost-80-0-56959400-1457206133_thumb.jpgpost-80-0-99103100-1457206175_thumb.jpg
On to the dial side, setting lever spring replaced:
post-80-0-17426700-1457206229_thumb.jpgpost-80-0-58108000-1457206234_thumb.jpgpost-80-0-22170400-1457206240_thumb.jpgpost-80-0-15017400-1457210051_thumb.jpgpost-80-0-18601500-1457206583_thumb.jpgpost-80-0-08179900-1457206587_thumb.jpg
Into the case, reattach winding gear, rotor  & caseback on:
post-80-0-32648300-1457206591_thumb.jpgpost-80-0-09512300-1457206596_thumb.jpgpost-80-0-19572200-1457206600_thumb.jpgpost-80-0-03835900-1457206604_thumb.jpg
The original crystal was used before the previous step to protect the hands, this is now removed the dial is given a final clean before putting the new crystal in place, which pushes on under finger pressure. The crystal is held firm by the bezel, which is a problem to fit as all of my dies are shallow & bevelled, unable to push the bezel down, so 2 pieces of 40mm waste water pipe are cut to suitable length, one piece is then fitted onto a stepped flat die, the other has a section removed and placed inside the first:
Works a treat. Finally, with a new tan alligator strap fitted:
It looks like the crown has been replaced with the wrong one in the dim & distant. Hopefully this will be rectified in due course.
  • Like 5
Thanks for posting an excellent walk through and great pics.
That is a really nice example too.
Thanks for the kind comments all.
Jdm - timegrapher reading as requested:
Taken dial down, there is a little variance on other positions & I will give it another look in a week or so once its bedded in. The original readings before service were: Rate +/-13 seconds, Amp 194, BE 1.2
Thanks a bunch!
Nice dial! Movement parts can often be scrounged; dials, hands, cases, not so much.
My parts pile demonstrates this very well :-)
Brilliant!  And so nicely photographed as well.  Oh how I wish my hands weren't so shaky as well as my confidence.  Looking at the pile of parts I would have no idea of the reassembly order.  This is where your craft and intelligence comes into play.  Bravo!
excellent tutorial! well done and easy to follow. that sportsmatic is a beauty. that is a great classic look with those beautiful dauphine hands. and these sportsmatics seem to have much larger indices than other seikos. maybe i'm imagining that  - but it seems so.
i've got three of them - and i think one more around here somewhere. mine are 6619's from 1964, 1967 and one i can't date. they're a nice dress watch and just the right size.
attachicon.gif13.jpgattachicon.gif14.jpgattachicon.gif15.jpgattachicon.gif16.jpgattachicon.gif17.jpg
attachicon.gif21.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif22.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif23.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif24.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif25.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif26.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 27.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif28.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif29.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif30.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif31.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif32.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 33.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif34.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif35.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif36.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 38.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 39.jpg
What a great job
    • Thanks for the info - I'll go big on the gaskets... Wonder if anyone sells hundred packs?!
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • Hi all, I'm almost ready to make my first attempt at watch repair. My initial goals are very modest, just to get an inexpensive watch or two to work on, and take it at my own pace. I have what I think are the necessary tools on the way. A couple of things arrived already: a loupe, some tweezers, and a cheap demagnetizer. After looking at the options for oils and grease, I decided to start off with Citizen A-O2 and A-O3 oil, and Seiko S-3 grease. The Moebius was just too pricey to buy this early into the undertaking, when added to the cost of the other tools I've bought. Screwdrivers are Kwong Yuen for now, but I took the frequent advice on tweezers and bought Dumostar 3C and will probably add more DuMont later. I'm looking forward to making a start. I'll need a watch to work on, so I'm trying to line up an auction purchase within the next week. I've been mostly looking at Seiko and Citizen, and will perhaps a Seiko Crown if I can land one at a decent price.
