I'm going to have to try some Ronsonal. I've been using Zenith hairspring cleaner. It seems to work okay, but it's expensive.
As far as I can ascertain both Ronsonal & Essence of Renata are basically the same, it just that the former can be bought cheaper & in bulk from fleabay. As for Ronsonal or similar having any affect on shellac I have yet to see it, having left pallet forks in the stuff for a week or more, then blasted in the ultrasonic without any ill effects......yet.
Yes, Ronsonal or lighter fluid will not attack shellac. Alcohol, however, will dissolve shellac and should be avoided on pallets and roller jewels.
Afternoon Guys,
I have just purchased and Tissot with a 2824-2 that needs a refresh.
I have repaired 2 of the same movement before but this will be my 1st full strip and re build.
What's the best way of cleaning the parts either by hand or ultrasonic?
do I need specialist chemicals? bear in mind I wont be doing this all the time :)
list of parts would be appreciated.
Many thanks
James.
post-1206-0-56116000-1439987291_thumb.jp
I think the movement is an ETA 2836-2. If so the strip down and drawings can be found on the ETA web site. It looks like the movement has had water ingress so a complete strip down,clean reassembly & lubrication will be required.
Agree with CB that acctually looks like a ETA 2836-2 movement . Tissot only has 21 jewels and has a different rotor .
Edited by rogart63
That's what was on the listing :) dont matter either way..... guess it's a better movement.
Any recommendations on the cleaning and magnification ??
Sent from my HTC One using Tapatalk
Hi Ginger, the 2.5x magnification should be fine for stripping and assembly, although being old and blind I tend to use a 3.5x. The 8" means you will have roughly 8" of space to work between the visor and movement.
If you are just starting off, I would recommend using Ronsol or Zippo lighter fuel and a small brush to clean the parts. An ultrasonic tank would be a lot better, but I would hold back on that and proprietary cleaners until you find out how keen you are going to be.
Excellent. I guessed as much on the 8".
Good tip about the lighter fluid :) thanks.
Hi ginger, I recently cleaned a movement that had similar signs of water ingress & I found this video Mark did very useful. Although it's of a 7750 movement,  he does show &  discuss a couple of methods he used to clean the particularly bad areas. I think it's round 14mins in https://youtu.be/BesSK67Mzms.
Hi guys. It's defiantly a 2824-2.
Hi guys, I'm looking for watch cleaning fluids, I've not used any before! So I'm looking types & makes of fluids, I've not got a ultrasonic machine yet, so I'll be cleaning parts by hand in glass jars....... Cheers!
Edited by bosstaki
Hi guys, I've been absent of late due to decorating to keep the wife happy. But I'd like to discuss a conversation I had with a friend who is the technical manager for a leading Swiss watch manufacturer. I asked him what he felt was the best degreaser to buy at present. He said" without question & nothing can compare, isopropanol which is available from the chemist. I was surprised to hear that they also use it in the final rinse pot during cleaning". He said you can't leave the lid off as it evaporates. He said it's ideal for the last rinse because of this fact.
Has anybody else used this product. I've just order 5ltr off amazon for £15,so pretty cheap.
Sent from my SM-G920F using Tapatalk
Hello!
I wash the parts in neophaline (benzine) but after that the parts sometimes have a thin layer of grease on them. For that I use isopropanol (isopropyl alcohol).
But be very careful - the alcohol dissolves the shellac so don't use it on the pallets and the balance wheel.
Bogdan
Hello!
Bogdan
Glad you told me that, I was going to drop the whole balance assembly in to degrease the hairspring.
I too use it as a final rinse when using water based cleaners in my ultrasonic cleaner, not for it's de-greasing qualities, but being alcohol it absorbs any residual moisture and aids drying.
Heed Bogdan's advice and never put anything with shellac in alcohol.
I clean the balance and hairspring mounted on the main plate. I rinse off the cleaner by submerging the plate in a basin of water at 50 degrees centigrade for about ten seconds, then blow off the excess water with a puffer. The plate is then placed in a container with alcohol and agitated with the puffer for about thirty seconds. I then remove the plate and place the plate onto a folded piece of kitchen roll to absorb the majority of the alcohol and gently use the puffer to blow air on the balance until it starts to swing correctly. At this point I remove the balance from the plate and store it separately until assembly. It is only at the point of assembly that I remove the balance jewels and clean them separately in lighter fuel.
Thanks for the detailed steps Geo, I assumed that would be the way to go, leaving the balance on the mainplate etc.. Just got confused, as Bogdan suggested not to clean the balance in alcohol.
Do not soak the balance for any great length of time if you will could have a problem with the roller jewel. That's why I say to dip it only for seconds before puffing it dry.
PS I have been doing this for years when cleaning parts in the ultrasonic tank and have never had a problem.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
