SCOTTY
17 hours ago, FLwatchguy73 said:
I just grabbed this vintage Citizen Bullhead with the panda dial. It's powered by the venerable Citizen, 23 Jewel,  8110A. It looks to be quite a disaster, but since I'm itching for a challenge and I've always wanted a Bullhead, this will be my chance.
Initial shopping list of parts includes:
  1. New crystal as I'm quite certain faceted crystals were never available from the factory
  2. New replacement or vintage dial in good shape as this one is a wreck.
  3. complete set of hands
  4. stem
  5. possibly a new balance as the hairspring looks to be wound tight, hopefully that is just a lack of perspective
  6. proper bracelet as this one is sans anything
As always, I will post updates and photos as I go through it. It seems Mark has yet to cover one of these on YouTube. Would love to see him go through one himself. If anyone here has gone through one of these or has any spares available, please let me know, I may need guidance. Hopefully I can manage it without one of those Bergeon 3rd wheel pullers as it costs nearly as much as this did.
Addendum: for those Quentin Tarantino fans, I just learned Brad Pitt's character, "Cliff Booth" in "Once Upon A Time in Hollywood" wore a gold tone one of these on a leather cuff band. :thumbsu:
I do like a man that likes a challenge ....:D
Seriously, IF you can find the replacement dial, it will be a great watch...:thumbsu:
Edited by JohnD
I agree! Already ordered this little honey.
Same seller had a Crystal, a crown, and a set of hands, negotiated a package deal, they're on their way
Result!!:woohoo-jumping-smiley-emoticon:
Timex Big Q two hander with pusher crown.
I have a similar watch already, but this one has the relevant metal clip for the pusher, so I can copy its construction for my other version. Hopefully I will end up with two good watches. Time will tell.
Today I received this beautiful Omega Genève from 1968 with blue dial. Iit was sold as not running, but with the optical condition and the ridiculously low price I just couldn't say no ^_^
When I opened it a screw fell right out the movement. I noticed that it should hold one of the caseclamps in place, which was missing. I guessed that the caseclamp made its way into the train of wheels, causing the watch to stop. So I carefully shaked the watch and volià, the clamp fell out and the movement began to run. I resecured the clamp with the screw. The movement looks really dirty though, so it will definitly benefit from a service. The results on the timegrapher confirmed that, so there is still work to do :)
 I also fittet an original Omega buckle to the strap.
  • Like 5
Some of my recent horological insanity.
No idea why this appealed, its just a cheap quartz jump hour, but I figured it was worth 0.99p
Blue dial.. Say no more.. also from the penny lots on ebay. That damaged bezel might require some creativity.
.. and a Timex.. because you can never have too many Timexes (apparently).
Edited by AndyHull
You seem to have the knack of finding the obscure watch bargains that I seem to miss Andy....if you ever come across a battered Timex Jump minute quartz, with a working movement I have a rather nice one, with a FUBAr'ed movement that I would like to get going....
Look for Timex "Q" ladies watches from that period, with the same "Timex '??' cell" designation on the back, and with two hands and a winder, the movement is not that uncommon in those. (Sorry I don't remember which cell it is). There is not much interest in them unless they are in immaculate condition so they usually go for pennies.
Check the coil is OK, and if so, give the thing a quick bath and spray the area round the crown with contact cleaner and see if it springs into life. They are not really serviceable apart from that, as the movements are heat staked or riveted together.
If that doesn't work, let me know, I'll have a look through my junk pile, I may even have one.
Edited by AndyHull
Fit the battery, then short between the two points marked X, and see if it springs to life. Remember it only ticks once per minute.
If it does wake up, then the issue is dirt in the contacts at the crown.
When you pull the crown it hacks, as I recall. This is done by disconnecting the + of the cell with contacts operated by the crown. If dirt gets in, these contacts get very nasty, but some electrical contact cleaner may well bring them back to life. If cleaning them doesn't work, but shorting the two points does, you might try tacking (soldering) a very small jumper wire between the two points I indicated. A bit of a nasty fudge, but it would get it going, at the expense of its hacking ability.
Edited by AndyHull
Thanks for the info Andy but my one has physical damage to the wiring of the circuit covered by the black plastic box....:thumbsd:
At the very least its going to need a crystal.
Internally however it looks reasonable, without any obvious battery juice related nonsense.
Filthy of course, but that's not a major issue.
Not sure of the date. It came in slightly over budget (but the postage was cheap, so I may give it honorary 404 club membership).
My Tissot chronograph, which I got for a song at a local Pawn shop, has been sold as I wasn't wearing it much. It was bulky and needed a link in the bracelet to fit more comfortably. I was seriously considering building a 7750 clone from eBay parts when I chanced across this Accurist chrono. It is powered by a Landeron 248. It looks to be of a late 60's vintage, but have no idea how to date them. Coming from the UK so it will be a couple weeks. It was sold as running, which is a plus, looks like it'll need a crystal polish for sure.
I absolutely ADORE the complexity of mechanical chronographs! :wub:
  • Like 5
More from the penny lots.
This time a Kienzle 57/03a black dial.
Hopefully I have something suitable to replace the missing stem, otherwise I may need so spend more on a replacement than I spent on the watch. The seller stated that the balance was good, so I suspect it should be relatively easy to restore it to its former glory.
Edited by AndyHull
Do you usually do luming when there is a need?
Sometimes. In this case I think I might. The watch is not a particularly high value item, so arguably not worth the effort, but the missing lume is quite distracting. It will give me a chance to experiment with "patina lume". Time to break out the acrylic paints to try and get a suitably aged colour I think. Plain fresh modern lume would look too bright.
Edited by AndyHull
If you decide to go for it, let us see the result please.
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
