Copying A Keyless Works Cover
mwilkes
I need to make a keyless work cover/setting lever detent for an ancient Rolex. I have the original from another watch. What's the best way to copy it? I've considered gluing the original to some steel stock and cutting around it, but I risk damaging the original if I do that....suggestions on a postcard please!
(I know I could buy one, but that wouldn't be character-building)
I would mark up the surface of the blank with engineer's blue, clamp the two together and mark around the old one with a fine scriber.
S
Ditto, but if you don't have Prussian Blue (either marking solution or engineer's blue) you can use a permanent felt pen or Xylelne marker.
Make sure your scriber or needle is nice and sharp to get a good outline.
PS: marking or layout blue is almost the same as engineer's blue but for the carrier solution. The marker has a fast drying solution while the engineer uses an oil based carrier and will not dry and will transfer to mating surfaces.
I'm with you on this Stuart, but I think you meant to say marking blue not engineers blue, they're different things. Engineers blue is for checking out high and low spots on surfaces.
Yes Geo... Absolutely right, lazily non-specific of me - I was taught to make marking blue by mixing engineer's blue with meths.
I've tried using xylene markers and they don't have quite the same effect imho, but almost as good
S
Whatever you use to mark the outline, make the holes and the index (the bumps that give the click) first.
Only then work on the outline. Otherwise you may find you have perfectly shaped piece but unusable due to the holes not being in the right places.
HTH
Anil
@anil yep - I ended up drilling holes first, then pinning the piece I needed to copy on to the blank using wire of the correct thickness for the holes. Every other way was prone to slippage - even superglue!
Gluing a paper template wasn't a go-er - the pieces were too small
For a source of flat steel, I've seen hacksaw blades being used to good effect...used ones are usually plentiful around a shop.
I've been tempted to try this out .. the added thickness of a sawblade is an asset as you can get the shape correct and thin it down as the final step. Better than trying to shape a thin plate.
Anil
Edited by anilv
I've often wondered if old clock main springs could be a suitable source of material, suitably annealed for working and then hardened and tempered before finishing.
This works Marc, make sure it's an old fashioned blue one though.
Wow!  How did you the steel that fine?
As regards the engineering blue.  I remember in metalcraft class (back in the stone age when I was a kid) the teacher used good old carbon paper or a stamp ink pad to mark parts for copying.
Edited by stroppy
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
