Copying A Keyless Works Cover
mwilkes
I need to make a keyless work cover/setting lever detent for an ancient Rolex. I have the original from another watch. What's the best way to copy it? I've considered gluing the original to some steel stock and cutting around it, but I risk damaging the original if I do that....suggestions on a postcard please!
(I know I could buy one, but that wouldn't be character-building)
I would mark up the surface of the blank with engineer's blue, clamp the two together and mark around the old one with a fine scriber.
S
Ditto, but if you don't have Prussian Blue (either marking solution or engineer's blue) you can use a permanent felt pen or Xylelne marker.
Make sure your scriber or needle is nice and sharp to get a good outline.
PS: marking or layout blue is almost the same as engineer's blue but for the carrier solution. The marker has a fast drying solution while the engineer uses an oil based carrier and will not dry and will transfer to mating surfaces.
I'm with you on this Stuart, but I think you meant to say marking blue not engineers blue, they're different things. Engineers blue is for checking out high and low spots on surfaces.
Yes Geo... Absolutely right, lazily non-specific of me - I was taught to make marking blue by mixing engineer's blue with meths.
I've tried using xylene markers and they don't have quite the same effect imho, but almost as good
S
Whatever you use to mark the outline, make the holes and the index (the bumps that give the click) first.
Only then work on the outline. Otherwise you may find you have perfectly shaped piece but unusable due to the holes not being in the right places.
HTH
Anil
@anil yep - I ended up drilling holes first, then pinning the piece I needed to copy on to the blank using wire of the correct thickness for the holes. Every other way was prone to slippage - even superglue!
Gluing a paper template wasn't a go-er - the pieces were too small
For a source of flat steel, I've seen hacksaw blades being used to good effect...used ones are usually plentiful around a shop.
I've been tempted to try this out .. the added thickness of a sawblade is an asset as you can get the shape correct and thin it down as the final step. Better than trying to shape a thin plate.
Anil
Edited by anilv
I've often wondered if old clock main springs could be a suitable source of material, suitably annealed for working and then hardened and tempered before finishing.
This works Marc, make sure it's an old fashioned blue one though.
Wow!  How did you the steel that fine?
As regards the engineering blue.  I remember in metalcraft class (back in the stone age when I was a kid) the teacher used good old carbon paper or a stamp ink pad to mark parts for copying.
Edited by stroppy
    • That's the right technique Mal đź‘Ť If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
