Replacing Incabloc Spring That Broke Off
I believe you need a replacement incablok spring (at least this is normal procedure as a replacement for the ETA 2824 et al, I'm not familiar with the very finicky-to-work-on -- according to others -- ETA 2892-a2). If you were on this side of world, I would say ofrei stocks them...but his prices for shipping outside USA are too high for a US$2 part. It is a pain sometimes to make those springs to catch on the end they are supposed to and finally close correctly (lyre type) the others (novodiac/kif) will get in with no problem...except when they want to jump and join the space junk orbiting the Earth.
It usually easier to remove the holder then to wiggle the incabloc spring  in and brake it again . Just pay attention to how far it's pressed in . And in what direction . Sometimes the date ring slides very close to the jewel . And there for has a cutout.
Edited by rogart63
Try cousinsUK for the spring...no need to pay for a whole watch...better to have 3 of each size just in case...IMHO.
Would this do for me? I actually have no idea which incablock to  get...
https://www.cousinsuk.com/product/inca-assortment?code=I38848
Or better: which of these?
https://www.cousinsuk.com/product/inca-shock-springs?code=incabloc%20springs
Edited by GeorgeClarkson
Sorry George,
I couldn't find a good reference for the right part, the service data doesn't list if I think, only as a full assembly if I'm not mistaken...if money is no object I would get the full set of springs from your links. That way I'll know which one to use for every watch I'll ever service...hopefully some one more knowledgeable on this movement can advise both of us.
Cheers,
Bob
Bob, I was thinking the same, but I found a watchmaker here on Germany who can replace the spring if I send the main plate to him. I do not have a staking tool, so even if I buy the spring I won't be able to install it. It would cost me some 50€ plus the cost of the spring, so we are There with the price. But I would be sure that the job is done correctly...
Excellent find GuiBer,
Thank you! One more piece of information for my modest watch "info" folder. I usually wing it trying different sizes. This takes the guess work out of the equation!
@George: George, maybe I'm not understanding well but for the spring I believe you don't need a staking tool. They just "attach" hopefully by inserting on end with your tweezers. Then, the two lyre ends are moved into position with the same tweezers. The first move is tricky but no staking. In my mind, and with a lot of imagination, it is the same principle as those battery lids we see in remote controls for tv: you have to attach one end so the other end can latch...and it comes with -- usually -- to plastic guides (or ears If you would).
Well, in this case, the back of the lyre has this particular shape that will fit the frame where it belongs. Usually you kind of push it at a steep angle and once it clicks in place it will act like a hinge, allowing you to close it over the cap jewel and eventually securing both ends of the lyre in their respective "grooves". I can't explain it right, words are not enough but hopefully you get the idea.
Or maybe I'm confused and it is different to other ETA's....
Maybe you can try first and if it doesn't work you can send it to your friend the watchmaker...but where is the fun if you don't try first! :)
Cheers,
Bob
@Guiber: yes I had found that link too, but don't really understand how to read it...
@Bob: I tried exactly what you said, but without breaking the spring completely apart there is no way I can remove it. And the problem is when I would try to put the new one: even twisting it will not come in. Since the incabloc is embedded in the mainplate there is no other way, I believe, that the spring will come on...
170.03 is the incabloc spring .
I supose that as the jewell in question is in the main plate, that corresponds to the bottom ("dessous" in french) of the movement, and so the spring should be the 173.03.
(Perhaps someone more experienced than me in this subject can confirm it ?)
George, in the doubt you can always order the two types, as they are not so expensive!
Edited by GuiBer
Here is a howto from the NAWCC forum. You do need a staking tool.
To replace incabloc springs--push the setting out of the cock or plate. Place spring in channel, (self explanatory when you get this far)
put jewel in place and lock down the spring.
reinsert the setting. Easier than it sounds.
You will need a jeweling tool or at least a good staking tool to do this properly.
Under  'Watch parts branded' Cousins lists the springs for ETA 2892-A2 at £2.95 per pack of 5. You need to be registered (no hassle).
Edited by cdjswiss
GuiBer I already decided to send the mainplate to the watchmaker... I don't have a staking tool and I do not want to try and damage further the movement.
I think you make the right decision as you don't have the proper tool to do the job!
So it's also good you have decided to get a staking/jewelling tool !
I mentioned the two because there are some works with jewels that I suppose cannot be made with a stacking tool.
I had found that thread too, hence my decision to send it to a watchmaker
Hi George,
I'm actually partial to theK & D 18R Inverto Deluxe Staking & Jeweling Tool Set , something like this:
They are a little more money but I believe they are well worth the extra expense. Of course, the Favorite would be another candidate but they are still more expensive and rare to find.
Cheers,
Bob
  • Similar Content
    • Drat and double drat i was looking forward to the royalties on that idea.
    • Compression Spring Various Size. This might be helpful. I have watch furniture restorers and how they go about this problem, they inject glue underneath with a syringe and clamp it, leave over night. Next day remove clamp and it smooth. You could use an iron but be careful not to burn the wood.  https://www.ebay.co.uk/itm/265697329513?chn=ps&_ul=GB&var=565484998457&_trkparms=ispr%3D1&amdata=enc%3A1jd_-94ilTHWZLQ3PxHeC1A73&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=565484998457_265697329513&targetid=1647205088320&device=c&mktype=pla&googleloc=1006662&poi=&campaignid=17206177401&mkgroupid=136851690655&rlsatarget=pla-1647205088320&abcId=9300866&merchantid=119334104&gad_source=1&gclid=Cj0KCQjwir2xBhC_ARIsAMTXk849TnBArEYdgv1DpHf_somCZYmB7ViqD3UtvNJJc_dn4kj0AFxBXngaArSAEALw_wcB
    • 🤣 i think your first statement is rather dramatic, but i will take it in good humour.  I think the thread speaks for itself John.  What we are aiming for and when i say we, thats not actually that many that have spoke up. Is to have a back up plan to keep members in touch in case the forum ever disappears. So in essence yes the group has maybe taken on a life of its own and would like to remain together forever ( 🤣 i can also be dramatic )  maybe more members need to give some input of how they feel about it or say they are just not that bothered.  Either way at least the question gets answered. Can i ask what the forum means to you and how you would feel without it ? Thats one answer Rich from one person, without knowing how others feel the thread was just a waste of time. Aw Rich are you saying you'd miss me ? I'm touched 🙂
    • you should go to the European patent office and look up watch patents. I'm guessing it's probably impossible to make anything related to watches without stepping on somebody's patent it's good that they expire with time. They've literally as far as I can tell patented everything and anything. this is why is pointing out their other formulas for the Epilam I'm pretty sure Rolex might have their own formula for instance. somewhere in the universe I was once reading things that were rejected for patents for basically this kind of thing. So yes there is rules on what can and cannot be patented but I'm sure things fall through the cracks.
