A friend wants to sell me this Vostok
Here is similar watch on ebay.
I am posting pictures of the actual watch.  I dont think it has ever been worn.  Ex husband bought it and I guess it went into a drawer.
Thoughts on this brand of Soviet watch?  I have wanted a CCCP watch for awhile, but have not spent the time to do the research.
image.png.0f8cb0fe2c83a4aaadde22de018cffc4.pngimage.png.6aa169d3e0d757ca9f1f7ca2b2fee900.pngimage.png.50397c75dbe7e357f14739e4b172a26d.png
Hi looks clean enough, most Russian watches are not finely finished but are usually robust,  is the watch a worker or not . If it’s been in a drawer for some time it would benefit from a service for sure. Oil dries up and dirt does find a way in also the mainspring if been left fully wound and not able to run most likely dry or mane set.  Try it for winding and running for say 24 hrs if you can
That's a Vostok Komandirskie. The problem is that they are worth about $20 to $50. Your friend might get insulted if you offered so little.
The lugs are quite close together at 18mm, making the strap seem skinny for a diver's style watch. I use a 22mm strap and cut off 2mm off each side to make it look more proportional.
17 minutes ago, Nucejoe said:
 Russian watches are junk, your friend must have discovered this fact.
I love my Russian watches. The Vostok Amphibia and Komandirskie... maybe not so much.
They are rough but robust. Can take a lot of abuse, unlike my Swiss Army watch which uses a quartz movement and just dies sitting on the shelf.
It's like an AK47 compared to a M16.
How would you rate an escape wheel thats not finely finished or compare to some modern Swiss that can run without lubrication.
Massey ferguson tractors are more robust.
Open a Audmars piguet to see what a fine watch is.
I bought some of these watches new in the 1990s for about 10DM (Deutschmark) each.
They are constructed well but (very) poorly machined and finished, as others said already.
I sold these watches some years ago for about €20,- each. Should have been waiting for better times 😆
Edited by Kalanag
Hi @LittleWatchShop getting the unvarnished truth out of a forum such as this is like getting blood from a stone.  You will get many diverse opinions, that’s what forums do  , extract opinions and from the result you then assemble your own data.     By the way Massey Ferguson aren’t any better than most tractors, stick to John Deere or AlisChalmers.   Cheers
11 hours ago, LittleWatchShop said:
Sometimes, I worry that I will not get the unvarnished truth on this forum.
One should be careful not to confuse the "unvarnished truth" with simple opinion based on an individuals personal experience (which can be base on as little as just 1 watch), preferences, and prejudices.
I like Russian watches (and I have serviced and repaired many) but they do have their faults.
Movement wise the designs range from direct copies, licensed or otherwise, of Swiss movements, to some highly innovative in house designs. Build quality can be somewhat variable, if you get a good one then fine, but if you're up for a bit of fettling then even the less that fantastic can be brought to acceptable levels of performance. The quality of finish ranges from quite acceptable to what can only be described as "agricultural", so the Massey Ferguson references have some grounding.
A lot of the 1970's and 1980's watches came in cases that had absolutely no water resistance, or even dust protection what so ever, so the movements often suffered from corrosion issues. The cases were generally chrome or gold plated base metal, and would wear through to the brass quite quickly. However the full stainless steel cases with a screw down back and a water proof crown were not too bad, and the Amphibia divers are pretty good.
This is of course a completely pointless comparison, you're not going to get high end Swiss watch levels of performance or finish from any budget watch where ever it comes from, but so long as you keep in mind that that is what most Russian watches are (budget), you shouldn't be disappointed. I don't know about current prices but it was only a handful of years ago that Vostok Amphibias could be had brand new for as little as £75 including shipping, find me an AP at that price point...
As @HectorLooi says
and it's a nice clean example, looks like a late '70's or early '80's vintage with a fairly well finished movement. The case is chrome plated brass rather than stainless steel but the chrome is in good order.The case back gasket appears to be missing but get that sorted and it should have reasonable water resistance. At the right price (I wouldn't pay more than £40) it should be a fun introduction to Russian watches, and of course provides you with the the opportunity to start to formulate your own "unvarnished truth" about them. It also opens up a whole world of customisation should you wish to personalise it.
Well worth reading if you're interested in these...
https://www.linkedin.com/pulse/vostok-watches-history-explained-muhammed-amjad
https://www.hodinkee.com/articles/vostok-amphibia
As @HectorLooi says
A good comprehensive opinion of Russian watches. I have something of an affection for them being the first watch i repaired was Russian which runs for almost 48 hours, with great time keeping on the wrist. I also have a few of the Vostok amphibias, known as scuba dudes although that logo is often seen on other divers. One is modded and lovely to look at, the wobbly crowns are a unique feature.
It's a AKA3 MO CCCP. Initially only for sale for the military or Westerners with US$. Seems a nice and clean watch. There is nothing wrong with these watches, provided they are not already tinkered to death. But this one seems in good & nice condition.
I've always said, and will say it again; especially the Vostok Amphibia is the best value for money (or for the US: "the most bang for the buck") you can buy on this planet. Nothing comes even remotely close.
Go for it 😉
Please note, this is the Amphibia 200mtr diver, not a Komandirskie. The Swiss could learn a thing or two from the Soviets / Russians.
Edited by Endeavor
I think of Vostok as the Timex of Russian watches. They take a licking ... you know the rest. They also produce some incredibly "budget minded" (aka cheap) watches, as well as some very decent timepieces with a long interesting horological history.
I have three Russian watches in my collection. A Vostok "scuba dude" just because it's cheap, quirky and fun. It's the VW Beetle of watches. A made-for-the-western-market Amfibia (spelled with a f instead of ph) that's a typical Vostok calibre with a bit more  finish on the case and dial. And a reissue of the Strela chronograph, the Russian version of the Omega moon watch.
Watches are like wine -- you can get good wine cheaply and some expensive bottles are pure vinegar. Don't let anyone tell you you're wrong for liking bulk wine in a box. And, that doesn't mean you can't appreciate a good vintage bottle from a well known cellar.
My opinion + $5 will get you a small regular coffee at Starbucks if you have a coupon.
Edited by eccentric59
In 1991 I bought a brand new Russian wrist alarm watch „Corsar“ for just 50DM (€25) from a department store in Stuttgart.
My initial excitement vanished immediately when I found, that the alarm spring could not be wound correctly. After opening the watch I found a ratchetwheel with the squared hole stamped about 0,5mm off center. So the ratchet wheel lost engagement with the crown wheel every turn. Hard to be fixed…
Unfortunately this was the one and only Russian alarm watch in the store.
The movement was a SU 2612,1 which is a copy of the AS 1930.
Edited by Kalanag
We had this a few months ago with another Russian watch, it turned out the rachet wheel could only be fitted one way on the arbor square. There was a 1 in 4 chance of placing the wheel correctly first time.
    • Hi Bob, Welcome to the forum and thank you for your service.  I would never try to discourage you from getting into this wonderful hobby/profession, but please be aware, it does not cost just a few dollars to get into watch repair.  Tools are expensive and in many instances the cheap knockoffs are worthless, especially when learning.  You can get the tools needed to disassemble, clean, inspect, reassemble and lubricate a watch without spending thousands, but as soon as you start getting into task-specific tools, there are so many and they don’t come cheap.  My suggestion is to start with the basics required to disassemble, clean, inspect, reassemble and lubricate only, and build upon that gradually as the need for other tools arises.  The advice above regarding starting out on working movements is gold. Many of the non-running watches on eBay have been bought, tinkered with, deemed too difficult and then sold again, often with more damage done each time.  Without experience, you clean and service a non-runner and it still doesn’t run. What now? Troubleshooting is difficult as a beginner. This can become very frustrating.  I would encourage you to buy a working movement, and learn to strip and service it. If it isn’t running afterwards, you know it’s down to you, and as long as you didn’t damage anything you know that the parts you’ve got can form a ticking watch. An excellent movement to start with is the ETA 6497 clones from China, such as the ST36. They’re not expensive, and although it finds use in some larger wristwatches, this movement was originally designed for use in pocket watches, so everything is larger and easier to see and handle.  Once you can service a new ST36 and have it running better than it did when it arrived, you’re definitely ready to step up to working vintage watches and then think about repair of non running or poorly running watches.  As far as cleaning solutions go, you will not do better than the commercial watch cleaning and rinsing solutions that are available. You’ll find plenty of suggestions for home brew cleaners online, but the professional products are superior and you want to give yourself every advantage you can, especially when you start working on vintage movements containing hardened decomposed lubricants and often years worth of other dirt and dust. Alcohol is ok for cleaning or rinsing movement parts that don’t contain any shellac. The pallet fork and roller table contain jewels secured with shellac and will tolerate a rinse in alcohol but not prolonged exposure. Methanol dissolves shellac faster than ethanol, and isopropyl alcohol dissolves shellac slower than ethanol. Just in case you don’t know already, the radium on the dial (and likely the hands) of your Dad’s Elgin is highly radioactive. It is safe enough when safely contained within the watch case, but the moment you open the watch and especially when handling the dial or hands you must take precautions against inhaling or ingesting any radium.  Best Regards, Mark
    • I have both sets and use the K&D 99% of the time.  Yes, you have to be careful with the pin.  I use a screwdriver to carefully release the pin from the spring.  Some skill is involved.   I have also modified/replaced the pins in the arbors as necessary.  Yeah, you would think a tool would not require modification, but such is the world of watchmaking.  There is no perfect tool.  Each watchmaker must the tools to his skill, or vice versa.
    • I have the 8-11mm K&D but it doesn't do a great job with modern mainsprings, or I have had terrible luck. The arbor pin protrudes too much and I have damaged more springs trying to disengage the arbor than I have successfully wound and inserted. It seems easier to use with old carbon steel springs. My Watchctaft set gets far more use, though I have to get creative to wind left hand springs
    • It depends on what the gaskets are made from but silicone lubricant should work.  Spray or rub on a generous amount, put in a sealed bag and wait a couple of days.  Test for softness and wipe off the excess.
    • For hardened gaskets, an experienced watchmaker told me he usually found heat to be the best to soften them up. I tried that on a '70's Tissot where the gasket had turned to essentially epoxy to no avail, but eventually got it off with a 5700 case back opener using a crowbar for leverage to turn the wheel.
