Low Cost Homemade Watch Parts
Michael
Progress to date on homemade watch parts, The movement is an Avia I bought off ebay for a few pounds. I will buy the glass and strap in the future (hopefully if things get that far).The plan is the rest of the parts will be DIY
Case fabricated in 3 parts
Raw material for case
post-143-0-96137300-1441055465_thumb.jpg).
  • Like 6
A bit more progress. Just the crown to make, put on some dial markings, and a clean up and tidy.
Hands made out of a broken main spring. Hour wheel extended
Fourth wheel ground down to remove sub seconds
Crown will be made out of an old brass bolt and fitted to an extended stem
Dial markings to be added
Watch is keeping good time
  • Like 5
Outstanding work Michael,
Truly impressed that you made those hands yourself but please tell, how did you manage to cut the spring steel to that accuracy, was it some sort of die or was it by hand.
Looking forward to the next installment.
Cheers,
Vic
Hi Geo, I had not thought of changing from the raw brass and just buffing when needed. However, your post has got me thinking. If I do anything I think it would be gold plated, unless you have any other suggestions?
Hi Vic, they were done by hand, and I am not entirely happy with them, but time restraints means I need to press on. The method I used was actually quite easy, and it was as follows;
Cut an over lengthed piece of main spring and bend reasonably flat
Soft solder at the ends to a thin piece of oversized brass. I used 0.5mm as it is what I had for the dial base
Drill the hole where it fits onto the hour wheel
Then use a dremmel type tool with grinding disc to shape your hand to how you want it. The brass helps to grip it, and also to control the grinding.
During the grinding the hand will naturally come away from the brass. Grind off to finally release the hand from brass sheet.,
Tidy up as required with dremmel type tool and then sand on a piece of wet and dry, both sides.
I put the hands on a 2mm piece of brass sheet and heated from underneath. As soon as hands start to turn light blue take the heat away
  • 4 weeks later...
    • A few years ago, I started out my workbench with a $50 oil kit from ebay with tiny quantities of 9010, HP1300, 8200, 9501, 9415. But the seller was from my own state and known personally by a professional watchmaker I'd taken a starter class with. She doesn't seem to still be selling kits though. This was for me, part of the initial investment and a development phase of "can I do this work, do I have the patience and dexterity." The economics of my quantities received vs the price originally packaged volumes were not really a consideration because I wasn't buying for long term or high throughput (as a pro would need). It was simply a matter of spending $50 on something I was uncertain to succeed at vs spending $150 with no greater guarantee of success. Just adding hobbyist perspective here. And I was fortunate that a professional watchmaker could vouch for my oil repackager.
    • I hope I took enough pictures. I am now going to clean everything and I am pretty uncertain about my ability to put it all back together.  The basic movement should be ok with likely some frustration when putting the big bridge on. But both the calendar side and the automatic parts will be stressful. Specially since everything is so tiny compared to the ST36 so many more parts
    • I have often to reshape stones, for example when I need to replace 'rolled over' or burnished type stone with a modern one. The other case is when a wider pallet stone has to be sized to tight fit the slot in the pallet fork. The tool that does this jobs is this kind of diamond disk. Grit 1000 or 800 is perfect for the honing. If the stone height is to be resized in the way Jon did, this will be enough to put the disk (the big one) on the table top diamond side up, put the stone on the disk, press it with finger and move it forward-reverse for a while on the disk surface, then try the height. If one is carefull and take measures  not to grind the surface bent, this will take no more than minute to resize the jewel. The same way I use to resize the pallet stones.  If a stone edge have to be rounded, then I turn on the top of a rod a 'nest' to receive the stone and glue there the stone with shellac, then while the whole thing is rotated, use the disk as a file to shape the stone.
    • I'm not saying for a second that the truly "cheap" watches aren't worthwhile (I have plenty of them too). Hopefully that's not what was conveyed. I just don't want to make it the primary focus any more than making finding a Rolex for $5 the primary focus. Anything anyone finds under the threshold they feel is worth the cup of coffee cost of entry is worth it in my book. I want the name to convey that, and not just "cheap" as that leaves out a big chunk of the fun of it. Cheap, yes, also diamonds in the rough, once in a lifetime finds, watches to learn on, and probably some other angle I'm missing. Something like "I skipped a trip to Starbucks for this!" (which sounds way too much like a clickbait listicle title) that doesn't make any judgements on the watches themselves, simply notes the price paid was low.
    • Yes- and even cheaper straight from the maker (and 30% off on top of that right now, 240 Euro) https://www.toolteam.com/de-DE/kaefer-jka-feintaster-40001-t-766312-4031452400014.html
